ᐅ How do you fix dents in Malm furniture?
Created on: 11 Apr 2023 19:07
Deoben
Deoben
11 Apr 2023 19:07
I have an IKEA Malm nightstand with several small dents on the surface caused by minor impacts. The dents are fairly shallow but clearly visible on the veneered wood. Now I’m wondering what the best way is to repair these dents without fully repainting the piece or damaging the veneer. I’ve heard of methods like steam treatment or polishing, but I’m missing detailed instructions and advice on the most suitable tools or materials.
Does anyone have experience with how to easily and effectively remove or fix these often subtle dents on Malm furniture? Tips on the procedure and recommendations for suitable products would be very helpful. Thanks!
chenValeri
11 Apr 2023 19:23
With Malm furniture, a combination of steam and light sanding often helps.
Place a damp cloth over the dent, then carefully steam it using an iron. This often raises the wood again.
Afterwards, if needed, use fine sandpaper and wood filler to smooth the surface.
Matthewt48
12 Apr 2023 08:39
Hello Deoben,
I completely understand that the small dents on your Malm furniture bother you. Veneered surfaces are often delicate, so it's important to proceed carefully. The steam method mentioned by chenValeri is based on the property of wood fibers to expand when exposed to moisture.
Here is my more detailed guide:
1. Slightly dampen a cotton cloth and place it over the dent.
2. Heat an iron to medium temperature (without steam) and hold it on the cloth over the dent for no more than 5 seconds.
3. Lift the iron and check whether the dent has risen; if not, carefully repeat the process several times.
4. Let the area dry thoroughly.
5. If any unevenness remains, you can gently sand it with very fine sandpaper (grit 240-320) and possibly touch up with suitable repair wax or stain.
It is important not to work too wet and to avoid damaging the veneer.
If you have a spot where the veneer is completely worn through, the repair is more complex and may require replacing the veneer, which usually calls for more advanced skills.
kieran
13 Apr 2023 11:52
chenValeri schrieb:
A combination of steam and light sanding often helps with Malm furniture.
That is correct. For dents in veneered surfaces, using steam is a proven repair method. The moisture causes the compressed wood fibers to swell back up.
Additional points to consider:
- The surface of the Malm table is coated with a thin layer of melamine resin, which is not very resistant to water or heat. Therefore, it is essential not to hold the iron in one spot for too long to avoid damage.
- Light sanding should only be done if the dent has only been partially raised and the surface still appears uneven afterward.
- After the repair, it is recommended to treat the area with a suitable wood care product or wax to even out the color and protect the surface.
- Alternatively, professional repair kits for veneered furniture are available that include color pastes and waxes to make small blemishes invisible.
The combination of a damp cloth, iron, and minimal sanding when needed usually delivers the best results without requiring extensive restoration work.
