ᐅ How do you repair damaged edges on a Malm nightstand?
Created on: 23 Apr 2017 10:43
Kaankla
Kaankla
23 Apr 2017 10:43
Hello everyone, I have unfortunately noticed some damage on the edges of my Malm nightstand from IKEA – the surfaces are chipped in several areas and it looks quite untidy. I am particularly interested in how to best repair these damaged edges so that the appearance remains as close to the original as possible and the stability is not compromised. I am curious both about the repair process using suitable materials (e.g., wood filler, edge banding, touch-up pens, glue) and about tool recommendations or how to ideally prepare and treat the damaged spots. Does anyone have experience or useful suggestions?
A bit of background: the nightstand has a laminate surface and is made of particleboard, so I’m unsure whether sanding is advisable or if other methods work better. I would really appreciate your help – tips on the proper procedure, products used, or alternatives that work well. Thanks in advance!
draleo
23 Apr 2017 11:17
For repairing damaged edges on the MALM nightstand, the following method is recommended: First, lightly sand the damaged area with fine sandpaper (grit 240–320) to remove loose particles and roughen the surface. Then, remove any remaining dust. For small chips, wood filler can be applied according to the instructions and smoothed out. After drying, sand again.
Since MALM nightstands are laminated, applying a matching edge band to damaged edges is also a good solution. The surface must be clean and dry. Edge banding can now be activated using an iron or a hot air gun.
Finally, repair markers in matching colors can be used to blend the surface. It is important to select materials carefully (color, texture) and to be patient during drying times to achieve a good result.
O
ottilie
23 Apr 2017 12:05
draleo schrieb:
Remove dust residues
Of course, this already sounds like standard advice, but when it comes to a MALM nightstand, I wonder if it’s more a matter of aesthetics. Most people just fix small damages with touch-up markers, but honestly – doesn’t that often feel like trying to cover a crack in a face with makeup?
Personally, I find it frustrating to make such repairs half-heartedly, especially since the edge banding or the laminate finish is what gives the furniture a high-quality look. So here’s my provocative view: it’s better to leave the damaged edge as it is and instead add creative adhesive decorations or attractive metal strips, rather than pretending to have a “clean surface.” But of course, that’s a matter of personal taste.
Kaankla
23 Apr 2017 12:52
Thanks for the initial responses, very helpful so far. @draleo: I have a question about using wood filler – wouldn’t that be too heavy or too thick for the thin edge of the furniture? I’m concerned that the surface might not smooth out evenly, resulting in a noticeable raised area that you can feel later.
@ottilie: Your idea of adding an accent with metal strips or decorative adhesive sounds interesting, but the nightstand is in a rather minimalist bedroom, and I want to keep it as original as possible. That’s why I’m looking for a repair method that is as invisible as possible.
Does anyone have tips on whether there are special fillers that can be applied very thinly, or if it’s better to work with edge profiles? I’d also like to know the best way to replace or repair damaged veneer on MALM parts. Thanks!
Laukau5
23 Apr 2017 14:08
Regarding your specific question about easily applied thin fillers: There are special furniture repair fillers and even liquid fillers that can be applied very thinly and are easy to sand once dry. It is important to first lightly roughen the damaged area and remove any dust. Then apply the filler in several thin layers, allowing each layer to dry thoroughly before applying the next.
Since MALM nightstands often have melamine or laminate surfaces, repairing them with conventional wood filler is not a perfect substitute for the laminate. An alternative is using self-adhesive edge banding with a laminate appearance. These bands come in colors similar to IKEA furniture and can be applied with an iron or a heat gun. This results in a visually clean edge.
For small surface damages, there are color-matched furniture touch-up markers designed to match the standard colors of IKEA furniture – be sure to check for the correct color codes here.
My tip at the end: If you have very high aesthetic standards, don’t just fill and sand the damage; instead, replace the laminate edge with a suitable new edge banding. This will give the cleanest final look.
barda6
23 Apr 2017 14:45
Ironing on edge banding is the best solution for MALM edge damage.
Clean off any dust beforehand. Even light sanding dust can prevent the banding from adhering.
If using filler, apply a thin layer, sand well, and cover with a touch-up marker.
