ᐅ How can chipped edges of Ikea HEMNES furniture be repaired?
Created on: 14 May 2022 18:23
christop39
christop39
14 May 2022 18:23
I recently noticed some chipped edges on my Ikea Hemnes furniture, especially on the shelves and door frames. Since these pieces are mostly made of solid pine wood with a lacquered or stained finish, I want to repair the damage as professionally as possible without it being noticeable or damaging the surface appearance.
Has anyone had experience repairing chipped or damaged edges like this? I am particularly interested in methods for filling gaps, suitable materials for restoring the surface, and advice on preparation to ensure the repair is long-lasting. Tips on appropriate tools and products (e.g., wood filler, colored markers, varnishes) would also be very helpful.
Thank you in advance for your tips and advice!
sinhau
14 May 2022 19:07
Hello christop39,
I would like to provide a structured guide on how to repair chipped edges on HEMNES furniture, especially when dealing with pine wood with a lacquered or stained finish:
- First, thoroughly clean the damaged area, removing dust and loose particles. Fine sandpaper (grit 180-220) helps to lightly roughen the broken spot.
- For filling larger gaps, I recommend a wood filler that matches the color of pine wood well. Important: apply the filler thinly, allow it to dry completely, and sand if necessary.
- Next comes color or lacquer adjustment. You can use special furniture repair markers that closely match the wood color. Some also use pigment paste or a matching lacquer, which can be softly dabbed or applied with a fine brush.
- Finally, a thin layer of clear varnish (matte or satin, depending on the surface) can provide protection.
Common mistakes include applying filler too thickly or sanding unevenly. With furniture like HEMNES, which is often oiled or stained, pay close attention to the exact surface finish.
I hope this gives you a good starting point. If you like, I can also share tips on specific products.
glapu
14 May 2022 19:45
sinhau schrieb:
Typical mistakes include applying the filler too thickly or sanding unevenly.
Exactly. I would also recommend not rushing the process: allow the filler to dry properly and sand lightly in between. For coloring, wax crayons from Ikea or a wood repair kit work well.
Gafiel
15 May 2022 07:58
to add some more detail, I would like to explain the repair process for HEMNES edges. As mentioned, the furniture is mainly made of solid pine wood, protected with a colored stain or a clear varnish. This means that even small impacts can damage the surface and the wood underneath.
To achieve the best possible result, I recommend the following steps:
- First, assess the severity of the damage to the edge. If it’s only minor scratches, furniture touch-up pens or wax fillers are often sufficient. For deeper defects, a two-component wood filler that can be sanded smoothly is a better choice.
- Apply the filler with a small spatula tool, making sure the material fully penetrates into all cracks. Remove any excess immediately, as filler otherwise dries unevenly.
- After drying, carefully sand the area smooth with fine sandpaper (220-320 grit). To blend into the original surface, use a sanding block to keep the edge as straight as possible.
- For color matching, I recommend testing the finish first on an inconspicuous spot. It’s best to use water-based furniture touch-up pens or stain colors applied with a small flat brush.
- Finally, seal the area with a suitable clear varnish; otherwise, the repaired section will remain vulnerable to abrasion and moisture.
A tip: if the edges are heavily worn or several areas are damaged, gently sanding the entire edge and resealing it can result in a more uniform appearance.
If you like, feel free to share the size of the damaged areas and the exact look of the surface — then I can provide more targeted advice.
christop39
15 May 2022 09:14
Gafiel schrieb:
If you like, please share how large the damaged areas are and what the surface looks like exactly – then I can help more specifically.
Thank you for the detailed answer! The damage varies – some spots are only a few millimeters (fractions of an inch) in size, especially on the front edges of the shelves, while others are a bit larger, about 1–2 cm (0.4–0.8 inches). The surface of my HEMNES furniture is satin-matte lacquered, not oiled.
I’m particularly interested in whether sanding and repainting the edge without color touch-up is sufficient or if you should always use filler first. Also, if you have experience with whether the usual furniture repair markers from the store really work well on satin-matte lacquer, or if it’s better to use other products.
Looking forward to your advice!
