ᐅ How do you repair broken hinges on IKEA PLATSA units?
Created on: 28 Dec 2024 10:17
lobla
lobla
28 Dec 2024 10:17
Hello everyone, I have an issue with the hinges on my IKEA Platsa cabinet system. Some hinges have become loose, causing the doors not to close properly or to hang unevenly. I’m particularly interested in how to professionally repair or replace these hinges if necessary. Is there a specific procedure to follow to ensure the doors sit firmly and neatly afterwards? I’ve already tried tightening the screws, but that only provides a temporary fix. Which replacement parts are suitable, and what tools are needed? I’d appreciate detailed advice or any handy tips you have from experience. Thank you!
Palenar
28 Dec 2024 12:43
Hello lobla, I am familiar with your issue with the IKEA PLATSA hinges, as it is quite common for these hinges to loosen over time. Essentially, there are two types of hinges used by IKEA for PLATSA: concealed clip-on hinge sets and simple inserted hinge systems.
For the repair, I recommend the following procedure:
- First, completely loosen all screws of the hinges on both the door and the cabinet frame to relieve any material tension.
- Check the screw holes for any widening or damage. For stripped holes in particleboard, it often helps to fill them with wood glue and small wood chips, let it dry, and then reinsert the screws.
- For the clip-on hinges, you should remove the hinges entirely and check if the metal springs still function properly and if the mounting plates are positioned correctly.
- When reinstalling, simply snap the hinges back into place.
- The adjustment screws for vertical and horizontal alignment are important to ensure the door is perfectly positioned.
In terms of tools, you will need a precise screwdriver (cross-head PH2), possibly some wood glue, and small wood pieces to repair damaged holes.
Here is an important tip: If the screws in the cabinet frame are too loose and repairs no longer hold, you can usually use metal threaded inserts to create a more stable connection. While these are not official IKEA replacement parts, they are very helpful.
Could you also please let us know if the hinges appear completely broken or if it is only the mounting screws that are loose? That would help with further diagnosis.
sanjon
28 Dec 2024 14:06
I would completely remove the screws, check the holes for damage, and repair them with wood glue if necessary. Then, reinstall all the hinges and use the adjustment screws to align the door. If the hinges themselves are defective, simply order replacements from IKEA.
Jensson
29 Dec 2024 09:38
Hello lobla, I would like to add to my experience report on repairing the hinges of IKEA PLATSA, because as always, the devil is in the details:
1. Preparation:
- Phillips screwdriver (PH2)
- Wood glue + small wood chips or wood filler
- Possible insert nuts (from a furniture fittings store)
- Replacement hinges from IKEA or suitable alternatives
2. Step-by-step instructions:
- Carefully unscrew the hinges and check for damage.
- Inspect the screw holes in the cabinet body. If the holes are too large or worn out, fill them with wood glue and wood chips, then let them cure.
- After drying, if necessary, carefully pre-drill the screw holes with a smaller drill bit.
- Check the hinges for functionality, especially the spring mechanism.
- Attach the hinges to the cabinet body with new or repaired screw connections.
- Mount the door to the hinge and use the adjustment screws to precisely align the door (horizontal, vertical, and depth adjustments on clip-on systems).
3. Common mistakes:
- Over-tightening screws and damaging the chipboard material
- Poor repair of the drilled holes, causing them to strip again quickly
- Mixing up the hinges (especially if a second type of door is installed)
4. Quick question?
Palenar schrieb:
Could you also say whether the hinges appear to be completely broken or if only the mounting screws are loose?
One more question for you: Is it a fully hanging door or just a door that closes loosely? This will help to better assess the exact issue and possibly required replacement parts.
I hope this guide helps you!
lobla
29 Dec 2024 15:52
Thank you for your detailed responses! To address Palenar’s follow-up question: The hinges themselves still look fine from the outside, and the spring mechanism works as well, but it’s actually the mounting screws on the cabinet body that are coming loose or have partially pulled out. This causes the doors to either sag or not close properly anymore.
The idea of using wood glue and wood shavings to fill the gaps sounds practical, and I will give that a try. I have never used threaded inserts before—could you give me some advice on the type or size that fits the PLATSA system? Do I need to drill special holes for them, or is it enough to widen the existing screw holes?
Also, what’s the best way to readjust the door? Is there a ‘standard procedure’ for adjusting the different screws in the PLATSA system to achieve a perfect result?
Looking forward to your recommendations!
Palenar
30 Dec 2024 08:19
lobla schrieb:
The idea of using wood glue and wood shavings to fill the gap sounds practical, I will give it a try.
Very good choice! Wood glue combined with finely ground wood shavings creates a very durable repair mixture that holds up well in everyday use.
lobla schrieb:
I’ve never used insert nuts before – can you give me tips on which type or size fits with PLATSA?
Regarding insert nuts: For IKEA PLATSA, I recommend M4 insert nuts with internal threads since the original screws usually have M4 threads. You need insert nuts suitable for panel thicknesses of 10–12 cm (4–5 inches). These nuts are hammered into pre-drilled holes and provide a very stable threaded connection. Here is the procedure:
- Clean the old screw hole and slightly enlarge it by drilling to about 12 mm (0.5 inch) diameter (depending on the nut size).
- Carefully insert the insert nut using a suitable installation tool (either a rubber mallet or an insertion plier).
[quote=lobla, post: y9l6q8, member: XXX]What is the best way to adjust the door? Is there a ‘standard sequence’ of adjusting the screws on the PLATSA system?[quote]
Yes, for PLATSA hinges it makes sense to proceed as follows:
- Slightly loosen the vertical screw (for raising/lowering the door) first, if needed.
- Adjust horizontally (side to side) until the door aligns flush with the cabinet frame.
- Then adjust the depth to bring the door surface close to the cabinet front.
- Finally, tighten all screws and test the door’s function.
Make sure to make each adjustment in small increments and only fully tighten the screws after completing all adjustments. This prevents misalignment.
One more tip: also check the position of the hinges during assembly – sometimes the spring gets stuck or the hinges are not fully recessed, which can affect the door’s position.
If you have any questions about installing insert nuts, just ask!
