ᐅ How do you reinforce your KALLAX for a home office setup?
Created on: 27 Jan 2021 08:23
Lipe33
Lipe33
27 Jan 2021 08:23
I recently set up an IKEA KALLAX shelving unit as the base for my home office, but I’m uncertain about how to reinforce the system. My KALLAX holds not only binders but also a small monitor and several heavy books, along with work documents and various electronics.
My question to you is: How do you reinforce your KALLAX shelving in your home office to make it stable enough for heavier loads and to create a durable, ergonomic workspace? Do you use additional panels, connectors, braces, or other constructions? What experiences have you had regarding its load capacity, and what solutions have proven effective in practice to prevent sagging or structural instability?
I look forward to your tips and to hearing how you have optimized your KALLAX for your home office.
Grace
27 Jan 2021 09:11
Hello Lipe33,
a very good and important question! KALLAX is indeed very versatile, but for heavier loads, it’s definitely advisable to add some reinforcements.
I generally recommend the following:
1. Reinforce the back panel: The thin back panel provides little stability, so I use plywood or MDF sheets cut to the same size as the backs of your KALLAX units, attach them with screws, and glue them.
2. Metal brackets: I screw metal angle brackets (corner braces) into the corners and joints, which helps stabilize especially under heavy weights.
3. Additional support beams: For shelves that bear a lot of weight, I reinforce the underside with an extra board or batten placed crosswise to prevent sagging.
4. Glue and screw: Instead of relying only on the snap-fit connections, I use screws with pilot holes so everything stays securely together in the long term.
Lipe33 schrieb:
wie verstärkt ihr euer KALLAX für größere Lasten?
Many people use KALLAX lightly, but if you place electronics on it, make sure to secure it properly!
I hope this helps you already! If you like, I can also provide examples of suitable materials.
tangi
27 Jan 2021 11:44
I would like to add to Grace’s suggestions:
The KALLAX is practical, but for permanent heavy-duty use, the thin shelves are not designed to handle it. Using plywood panels with a thickness of 15-18 mm (0.6-0.7 inches) as a replacement or base, placed directly on the KALLAX shelves, helps a lot.
The included plug-in system can loosen over the years, which is why screws and especially diagonal braces on the back panel provide significant improvements in stability. Combined with the plywood back panel mentioned by Grace, this creates a very solid structure.
If you want to place a monitor on the KALLAX, make sure that the surface is perfectly level and free from any sagging.
Grace schrieb:
Reinforce back panel: The thin back panel provides hardly any stability, so I use plywood panels
Exactly, that is the most important point. Then add sturdy brackets and screws—hardly anything more is needed.
Jamalli
28 Jan 2021 15:05
I generally see the idea of reinforcements as a good one, but it is also important not to exceed the limits of the KALLAX system.
For me, the fundamental question is: Is the system really meant to serve as a load-bearing surface for equipment, or do we simply want to enhance storage space?
Lipe33 schrieb:
so that it is stable enough for heavier loads and a permanent, ergonomic workspace
That sounds to me almost like the KALLAX is supposed to replace a desk. In that case, it might be better to choose a sturdy frame combined with a continuous worktop. The KALLAX units can certainly be used as storage, but I would not recommend them for full load-bearing purposes.
For reinforcement: plywood boards, brackets, and gluing can help, but they are not a cure-all for heavy loads. You have to think structurally—over time, the material and joints will suffer.
Do you have precise information on how much weight will be placed on which surface? That would be important for further considerations.
NUPIN
29 Jan 2021 07:37
Hey everyone! I find this topic really interesting because I’m currently working on my home office too.
I reinforced my KALLAX like this: first trick – I added an extra 18mm (0.7 inch) MDF board on top, which makes the surface very stable! Then I installed small metal cam locks that pull everything tightly together and make it rock solid! 🙂
Jamalli schrieb:
whether it might be better to choose a stable base frame combined with a continuous worktop
Sure, that would be perfect, but I wanted to keep it as affordable and flexible as possible. And what can I say: so far it’s holding up really well – even heavy binders and my large monitor!
So, just be bold and give it a try. You can easily upgrade the KALLAX with simple materials you can find at any hardware store. Cool project!
