Good morning everyone, I am currently looking into how to effectively improve the stability of Ikea Hemnes beds, especially the models with slatted bases and storage. In my apartment, the bed noticeably wobbles after some time when getting up or sitting down, which is obviously annoying in the long run and could also accelerate material wear. I have already considered some basic options, such as adding braces or extra spacers, but I would like to know about practical experiences on this topic. I am interested in whether existing connections can be improved without making major changes to the frame, as well as tips for additional stabilization methods that can be implemented with commonly available materials. What measures have you found effective to make the HEMNES bed sturdy and free of wobbling?
Regarding the question about increasing stability in Ikea HEMNES beds, it should be noted that the construction made of solid pine wood is generally sturdy but not indestructible. Wobbly bed frames usually result from loose connections, especially at the corner joints and the center support beam. It is advisable to systematically check the existing screw connections and additionally secure them with suitable wood glue. For reinforcement, you can either use washers under the screws to relieve pressure on the wood or attach special metal brackets as additional connectors at the corners. Mortise and tenon joints can be stabilized by inserting small wooden dowels to improve the fit. For beds with a center rail, reinforcing this rail with a sturdy wooden or metal slat is also helpful to reduce sagging.
I would like to add that when reinforcing Ikea HEMNES beds, special attention should be given to the slatted bed base support. The support points often become a weak spot due to fatigue. I recommend installing additional support slats parallel to the existing ones to better distribute the load. Additionally, reducing the spacing between the slats can improve overall stability. Another proven method is installing a central support beam under the slatted base, which is directly attached to the bed frame. This central beam should be made of a durable material, such as beech wood or metal. This significantly reduces sagging and makes the bed much more stable overall.
JULIANNALO16 May 2020 11:33Tightening screws, installing metal brackets at the corners, attaching a center strip under the slatted frame – this often leads to significant improvements.
Dwight49 schrieb:
You can reinforce plug-in joints by inserting small wooden dowels, which improve the fit. Great, this idea with wooden dowels can indeed reduce wobbling because they hold the joints tightly together. Maybe just drill and insert some yourself—it costs very little and is a solid DIY solution.Also, with my HEMNES bed, I noticed that placing a rug under the feet can sometimes cause slight slipping. A firmer surface underneath can indirectly increase stability. Small details often make the difference.
