ᐅ How can Malm dressers be reinforced to support heavier loads?
Created on: 19 Jun 2018 08:37
lenfu
lenfu
19 Jun 2018 08:37
I own an IKEA Malm dresser that I would like to reinforce for heavier loads. The standard construction doesn’t seem sturdy enough for my needs, as I plan to store very heavy items in it—sometimes several kilograms (pounds) per drawer.
My question is: What are the options to permanently strengthen a Malm dresser so it can handle significantly higher weight without compromising its functionality or design too much?
I have considered adding extra wooden slats, reinforcing the drawer bottoms, or using metal brackets, but I’m unsure what would be the most practical and effective solution, especially without completely rebuilding or damaging the dresser.
Does anyone have practical experience or tips on how to increase the load capacity of Malm dressers? Advice on materials, fastening methods, or common weak points would be very helpful.
Thanks in advance!
Connor
19 Jun 2018 09:02
lenfu schrieb:
What options are there to permanently reinforce a Malm dresser so that it can withstand significantly higher loads without compromising functionality or design too much?
Honestly, who really needs the original design when a few steel braces can practically make it indestructible? ;-) In my opinion, most people don’t reinforce it enough. For very heavy loads, I would recommend adding metal brackets inside the corners—especially at the bottom of the side panels.
Also, consider investing in thicker plywood boards as additional shelves. The standard Malm shelves are simply thin and don’t carry much weight. If you install them carefully, the external appearance stays mostly unchanged while the load-bearing capacity increases significantly.
Of course, this is for DIY enthusiasts who are comfortable using a drill and screws. Otherwise, such a piece of furniture can only withstand heavy weight to a limited extent.
temeli
19 Jun 2018 09:47
It's great that you're considering heavier loads for your Malm! 🙂
I once reinforced a similar dresser with metal strips attached inside the drawer sides and underneath the bottoms – it holds up really well!
If, like lenfu, you care about the appearance, you can use thin metal profiles and paint them to match the color. That way, they’re hardly noticeable, and your piece of furniture benefits.
And very important: check the screws on the drawer slides and if necessary, replace the thin particleboard screws with sturdier metal screws that have a thicker core – that adds extra stability!
Good luck with reinforcing it, it will turn out great :-)
naujon
20 Jun 2018 11:16
Hello lenfu,
here is a structured guide on how to reinforce your Malm chest of drawers:
1. Check weak points: In particular, the drawer bases are usually made of thin particle board that bends easily. Therefore, the drawer bottom is the first candidate for reinforcement.
2. Retrofit the bottom with plywood: Replace or supplement the existing bottoms with approximately 12–15 mm (0.5–0.6 inch) thick plywood sheets. These come in various sizes and can be cut to fit. Plywood is more stable and durable.
3. Angle brackets: Additionally, install metal angle brackets at the inside corners of the chest to better connect the side panels. This significantly increases overall stability.
4. Reinforced screws and dowels: Replace the original screws with longer and thicker versions or wood screws with a larger diameter so the joints don’t loosen under load.
5. Check drawer slides: To ensure proper drawer function with increased weight, consider using slides with higher load capacity or adding additional guides.
Summary: The combination of thicker bottoms, metal brackets, and stronger screw connections makes the difference. Avoid complete disassembly, but after these adjustments your Malm will handle much more stress.
If you have questions about the exact implementation, feel free to ask again.
Elodie
20 Jun 2018 18:51
Connor schrieb:
For really heavy loads, I would recommend reinforcing the dresser from the inside with metal brackets at the corners
That’s pretty spot on and sounds easier than you might think! 🙂 I once reinforced my Malm dresser with a few cleverly placed strips under the shelves – invisible from the outside, but significantly improving the load capacity.
Another important point is to not only focus on the shelves but also on the back panel! Often the back panel is just a thin hardboard, which adds little to the overall stability. A few screws and reinforcing strips here can make the whole structure much more rigid.
All in all, a dresser doesn’t have to be fragile if you add a few counter-screws. A bit of DIY – and it can hold much more than you expect. Good luck upgrading! 😉
