ᐅ How can you protect the edges of Ikea BRIMNES furniture from wear and tear?
Created on: 21 May 2021 14:37
seruba
seruba
21 May 2021 14:37
Some time ago, I bought an IKEA Brimnes furniture piece, and I noticed that the edges—especially in areas that are frequently touched or positioned against walls—show signs of wear and tear quite quickly. I’m interested in practical and effective methods you know to protect the edges of Brimnes from damage. I’m thinking not only of short-term solutions but also of long-lasting measures that work well with the materials involved (e.g., plastic, wood veneer, etc.).
It would also be helpful if you could share information about suitable materials or installation aids that help preserve the edge appearance and durability without affecting the overall look of the furniture.
Thank you in advance for your advice!
besau
21 May 2021 15:02
I recommend simple edge protection profiles made of soft PVC that can be adhesive-mounted. They are available in various colors and usually match furniture well. Alternatively, self-adhesive furniture foil can be applied to the edges, which protects against wear and looks neat.
bapar
21 May 2021 20:18
To answer your question precisely, it is important to first understand the nature of the BRIMNES edges. They are usually made of melamine-coated particleboard, which is affordable and visually appealing but can be prone to micro-wear, especially on the corners due to the hard surface.
For long-lasting protection, especially for frequently used furniture, I recommend the following steps:
- Cleaning: First, thoroughly clean the edges from dust and grease to ensure good adhesion of any adhesive material.
- Edge Protectors: Flexible plastic strips or protective profiles, commonly available at hardware stores as edge protectors for furniture, work well. It is important that they fit the width of the edge.
- Installation: Use some assembly glue (not general-purpose glue, but one specifically for plastic on wood) to ensure durable bonding. Cable ties or clamps can help hold the protector in place while drying.
- Alternative: Instead of strips, multiple coatings of clear varnish or furniture wax can provide minimal protection against surface wear. However, this does not protect against mechanical damage.
Could you also tell me if your BRIMNES furniture is located in a heavily used area or if there are children in the house? This affects the type of protection needed.
Additionally, how important is the appearance of the furniture after applying protective measures? Should the edge protection be as inconspicuous as possible?
seruba
22 May 2021 09:41
bapar schrieb:
Could you also share if your BRIMNES furniture is placed in a high-traffic area or if there are children in the house?
Good question! Yes, the furniture is in the living room, right next to the passage door, so it’s frequently used. I don’t have any children, but heavier objects sometimes bump into the edges when passing by with bags or similar items.
bapar schrieb:
How important is the appearance of the furniture after applying protective measures? Should the edge protection be as invisible as possible?
I want to change the look of the furniture as little as possible. A visible plastic edge would be a last resort; I’d prefer a discreet or invisible solution. At the same time, the protection shouldn’t be merely surface-level but should effectively prevent wear and tear.
Does anyone have experience with clear protective coatings or special sealants that adhere well to BRIMNES edges and don’t affect the gloss?
kemeo68
23 May 2021 11:57
seruba schrieb:
I want to change the furniture as little as possible visually. A visible plastic edge would be a last resort for me
But why exactly? Sure, some people want a perfect look, but if your nicely sharp edges keep getting scuffed, I think it’s almost self-deception to prioritize the “invisible” protection above everything else.
And honestly: These DIY attempts with paint and wax often don’t work because the protection layer is thin and vulnerable. In practice, only something that actually builds up material on the edge and protects it from mechanical stress really helps, and that usually looks a bit different from the plain furniture surface.
So: Either you fully commit to the appearance and forego long-term protection, or you accept visible but functional edging strips. The “golden middle” is often just wishful thinking.
