ᐅ How can IKEA PLATSA furniture be protected against moisture?
Created on: 26 Apr 2024 09:37
Corneliasi
Hello everyone, I have installed IKEA PLATSA furniture in an area of my home that sometimes experiences increased humidity, due to nearby windows and occasional ventilation during variable weather. My specific question is: How can IKEA PLATSA furniture be effectively protected from moisture damage without compromising the furniture’s function and design? I would like to know which preventive measures have proven effective in the long term, especially regarding possible mold growth, material deformation, or wood swelling. Are there particular products, surface treatments, or construction adjustments that you would recommend? I would greatly appreciate practical tips and experiences with these furniture pieces in humid conditions.
Fitigu
27 Apr 2024 10:43
For clarification: The particle boards used in Platsa furniture are sensitive to moisture, as it can cause swelling and potentially compromise stability. Therefore, it is important to:
- Maintain a gap between the furniture and the floor
- Avoid placing the furniture close to water sources
- Control the indoor humidity (ideally below 60%)
- Use appropriate sealants
A simple surface treatment with clear varnish or furniture oil can also provide protection, but compatibility should be tested first, as aggressive products may damage the laminate coating.
Ramon4
27 Apr 2024 15:07
tra_nina schrieb:
Avoid prolonged indoor humidity by ensuring proper ventilation.
This is really crucial. I also recommend following the manufacturer’s instructions during installation—do not overload shelves, so the structure is not unnecessarily stressed, which can cause issues in high humidity. Another tip: For damp walls, installing a vapor barrier on the wall side is a sensible construction measure before placing any furniture.
benon
28 Apr 2024 09:55
Davidleo schrieb:
I treated my PLATSA furniture with a matte nano-sealant and haven’t had any issues with moisture since.
That sounds like a good solution! However, it is important to note that nano-sealants are not always breathable, which can lead to moisture buildup behind the coating. Therefore, I recommend applying it selectively and only on particularly vulnerable areas.
I also suggest placing hygrometers in humid rooms to monitor the air humidity. This way, you can respond early if the levels rise too high.
Corneliasi
28 Apr 2024 11:34
Ramon4 schrieb:
Another tip: For damp walls, installing a vapor barrier on the wall side is a practical construction measure before placing any furniture.
Thank you for the advice! I actually have an exterior wall where moisture often rises – so far, there has been no vapor barrier. This seems like a sensible step before taking further measures concerning the furniture itself. Are there any recommendations for an appropriate installation method that is compatible with IKEA furniture like PLATSA? I would also be interested in how much space should ideally be left to ensure optimal air circulation behind the furniture.
