ᐅ How can IKEA BRIMNES surfaces be protected against moisture?
Created on: 21 Dec 2021 14:37
Listeo5
Listeo5
21 Dec 2021 14:37
I recently bought the IKEA Brimnes bed and have noticed that the surfaces are unfortunately quite sensitive to moisture. In the bedroom, humidity levels tend to fluctuate, and I want to avoid the melamine coating or the partially painted areas from swelling or discoloring.
My question is: What is the best way to protect the IKEA BRIMNES surfaces from moisture? Are there proven methods to keep the furniture durable over time without resorting to drastic measures that might change the appearance? I am especially interested in practical tips that can be done by oneself, such as sealants, special cleaning products, or construction-related measures like ventilation or keeping a certain distance from the floor.
I look forward to your experiences and advice!
DULIS
21 Dec 2021 15:11
Simply avoid getting moisture directly on the surface. It is best to occasionally wipe it with a dry cloth. If it does get wet, dry it immediately.
Additionally, using a dehumidifier or regularly ventilating the room can be helpful.
Domau0
21 Dec 2021 18:22
The protection issue with BRIMNES furniture mainly stems from the combination of particleboard with a melamine resin coating, which offers some resistance to water but can swell if exposed to moisture for an extended period.
For prevention, I recommend a multi-step approach:
- Use microfiber cloths to gently remove moisture without causing scratches.
- Always let the surface dry completely after cleaning.
- A thin layer of furniture wax or a care product specifically designed for melamine and laminate surfaces can provide additional protection. It is important not to use oil-based or water-based care products that might absorb moisture.
- Regular ventilation prevents high indoor humidity, which can negatively affect sensitive particleboard.
Additionally, I would check if the furniture is actually placed directly on a cold floor. A few centimeters (inches) of clearance improves air circulation underneath and prevents moisture accumulation.
Could you please describe in more detail how much moisture occurs in your bedroom or if frequent ventilation is possible there? This would help provide more specific advice.
Listeo5
22 Dec 2021 09:06
Domau0 schrieb:
Could you describe more precisely how much moisture is present in your bedroom, or whether frequent ventilation is possible there? This would allow for more targeted advice.
Thank you for the detailed post, Domau0.
The bedroom is small, and after ventilating in the morning, heavy condensation often appears on the windows. The average humidity levels fluctuate between 50% and 70%, especially in winter due to the dry heating air. I ventilate in short bursts in the morning and evening, but sometimes the outdoor temperatures make this difficult because the room then cools down too much.
Some furniture is placed directly on the laminate floor; I haven’t yet used any special spacers. That sounds like a good point to consider adding them.
Would it be worthwhile to use an additional dehumidifier in such a case? And are special care products for melamine coatings recommended that provide long-term moisture resistance?
Benge5
22 Dec 2021 11:58
Listeo5 schrieb:
Would an additional dehumidifier be worthwhile in such a case?
Yes, especially when humidity levels exceed 60%, electric dehumidifiers are quite effective in reducing moisture and thus significantly lowering the risk of damage to furniture surfaces like those on BRIMNES.
Listeo5 schrieb:
Are special care products recommended for melamine-coated surfaces that permanently repel moisture?
In general, the melamine surfaces used by IKEA are moisture-resistant, but it is still advisable to use a suitable protective wax or laminate care product that seals the surface. It is important that the care product is suitable for melamine resin-coated furniture—products with water- and stain-repellent properties are highly recommended.
Alternatively, silicone-free sprays can be used to make the surface hydrophobic, but these need to be reapplied regularly.
One more tip: avoid placing furniture directly against exterior walls, as these areas often have higher moisture levels.
Elodie
23 Dec 2021 08:45
Listeo5 schrieb:
How can you best protect the IKEA BRIMNES surfaces from moisture?
You asked a great question, and there’s quite a bit to cover. In general, BRIMNES is sturdy but not really designed for bathroom use.
My tip for bedrooms: you can apply an invisible protective layer to the surfaces, for example, a very light wax or a sealant typically used for laminate flooring. This will protect against minor splashes and the moisture in the air.
I also recommend avoiding placing plants directly beside or on the furniture – plants add moisture, which is often underestimated. And yes, a small electric dehumidifier can work wonders, especially during cold winter days when airing out the room is difficult.
And just wipe it regularly with a dry cloth – that keeps the surface fresh and dry. BRIMNES will thank you for it! 😉
