ᐅ How do you properly secure Ikea PLATSA furniture to the wall?
Created on: 25 Jun 2020 18:23
LalotraHello everyone,
I am planning to purchase some IKEA Platsa furniture and currently have questions about how to correctly and securely fix these units to the wall. Since PLATSA consists of modular furniture that can be combined in various ways, I am especially interested in the available mounting options and what to pay attention to when attaching them to different wall types.
For my previous furniture, I often used wall plugs and screws, but with PLATSA there is also the option to use connectors and special wall brackets. What are your experiences with these? Are there any essential safety instructions, special tools, or recommendations regarding the spacing of the mounting points?
I would also like to know if it is important to distribute the load differently when combining or stacking multiple cases.
Thank you in advance for all helpful tips and advice!
the most important point is to choose the right anchor for your wall (concrete, plaster, drywall, etc.). Use the IKEA wall brackets with the included screws. Make sure to fasten the brackets in each unit at least in two places per cabinet.
If you combine several cabinets, you must also connect them to each other to prevent any wobbling. Otherwise, simply follow the instructions carefully.
Hello Lalotra,
I’m happy to provide a more detailed guide since mounting PLATSA is not always straightforward.
1. Determine the wall type: This is crucial because depending on whether you have a solid concrete wall, a brick wall, or a drywall (plasterboard) wall, you will need different types of wall plugs (e.g., cavity anchors or metal expansion anchors).
2. Use the wall brackets supplied by IKEA. These are designed to distribute the weight evenly across the wall.
3. Decide on the mounting height: Make sure to position the modules so that the brackets are attached to solid parts of the wall – placing them too close to edges or joints can reduce the holding power.
4. Connect the individual modules with the provided connectors to prevent slipping and tilting.
Common mistakes:
- Mounting only at the top rail. It’s better to use multiple fixing points.
- Using wall plugs unsuitable for the wall type.
- Overloading the modules without sufficient wall anchoring.
The IKEA instructions are helpful, but I also recommend always using a spirit level and tightening the screws firmly, but not excessively.
If you need more details, just ask anytime.
Common mistakes:
Hello Lalotra,
I would like to add that the correct installation of PLATSA furniture indeed involves some technical details.
First, it is important to know the load capacities of the individual modules. IKEA provides weight specifications for their load-bearing capacity, but whether the wall can support these loads long-term depends heavily on the mounting technique and the wall material.
The pre-installed wall brackets on PLATSA are designed to distribute the weight not only at a single point but across a larger area of the back panel. However, if you plan to stack multiple cabinets vertically, you should definitely -
- securely connect the modules to each other using the included connectors,
- make sure to attach the mounting points not only to the upper back panel rail but also, if possible, to stable points along the frame,
- equip the wall with suitable anchors, such as metal anchors for concrete or special cavity anchors for drywall.
Additionally, I strongly recommend using a good cordless drill with torque control for all fastenings to avoid over-tightening screws and damaging the anchors.
One more tip about mounting height: always mark the positions precisely with a spirit level and avoid installing the furniture so that it extends over door frames or window lintels. These construction areas can represent structural weaknesses.
Can you tell me how your wall is constructed? Then I can give more specific recommendations regarding the types of anchors.
nera59 schrieb:
1. Determine the wall type: This is essential because depending on whether you have a solid concrete wall, a brick wall, or a drywall (gypsum board) wall, you use different types of anchors (e.g., cavity anchors or metal expansion anchors).This is an important question, thanks for pointing that out. My wall is a brick wall with plaster, so it’s fairly sturdy but not as solid as concrete.
Le_kin schrieb:
Can you describe how your wall is constructed? Then I can give more specific recommendations regarding the types of anchors.You’ve already helped me a lot with that.
I also wanted to know if there is a standard for the number of wall brackets: For example, for a 1-meter (3 ft) cabinet box, is it enough to screw two or three mounting points into the wall? And for multiple boxes stacked on top of each other, correspondingly more—but how exactly do you plan that?
Is there also a maximum number of modules you can safely stack, without the load on the wall brackets becoming critical?
Regarding the question about the number of wall brackets and the maximum stacking height, the following can be clarified:
- For a single cabinet approximately 1 meter wide (3 feet 3 inches), at least two wall brackets should be used, ideally placed on the outer sides to prevent tipping.
- When stacking multiple cabinets on top of each other, IKEA and most experienced users recommend additionally securing the modules with official connectors between them. These connection points prevent the modules from shifting against each other.
- The number of wall brackets increases proportionally with the height of the construction. A rule of thumb is: for every additional 50 cm (20 inches) of module height, at least one extra wall bracket per side.
Regarding load-bearing capacity, a brick wall is well suited for moderate loads, provided the appropriate wall plugs are used. Metal dowels or heavy-duty anchors are recommended in your case.
Concerning the maximum stacking height, IKEA generally recommends structures up to 2.4 meters high (7 feet 10 inches), as long as all connections are securely fastened and wall mounts are properly installed. Taller structures usually require additional supports or floor anchors.
In summary: the quality of the wall mounting and secure connection of the modules are crucial for the safety and load capacity of the PLATSA furniture.
