ᐅ How do you properly secure IKEA Brimnes shelves to the wall?
Created on: 18 Sep 2021 08:37
Z
Zionbau
Good morning everyone, I recently purchased an IKEA Brimnes shelf and now want to securely and properly fix it to the wall. My question is which steps and materials you would recommend to ensure the shelf is especially stable. I am particularly interested in how to best anchor the brackets into the wall, whether the type of wall plugs is important, and what to consider with different wall types (e.g., drywall, masonry, concrete). Are there any special tips or common mistakes to avoid when mounting the Brimnes shelves? I look forward to your experiences and advice!
Zionbau schrieb:
My wall is actually a regular brick wall, not drywall or concrete.That’s clear, thanks for the information.
For a brick wall, you should definitely invest in heavy-duty anchors. Plastic expansion anchors can work if they are large enough (at least 8mm diameter), but I recommend metal expansion anchors or so-called heavy-load anchors, especially if the shelf will carry weight.
- Drill hole: Usually, 8mm holes are standard for such anchors, but it’s best to drill according to the anchor size.
- Screws: Yes, longer screws (e.g., 50–60mm) provide better grip in the shelf itself, which makes sense.
One particular point with brick walls is that you should not only pay attention to the anchor but also make sure the anchor sits well in the wall and not directly in the mortar joints. The bricks are sturdier than the mortar. If possible, avoid drilling directly on the joint.
Do you have a hammer drill? Otherwise, drilling will be difficult.
I hope this helps you!
Zionbau schrieb:
Are there any advantages or disadvantages of these types of anchors for brick walls, or maybe recommendations for the drill hole size?Just a quick addition: For brick walls, nylon anchors are usually sufficient if they are properly sized.
- An 8mm (5/16 inch) drill hole for an 8mm (5/16 inch) anchor is standard.
- Metal expansion anchors hold better but are often more complex to install.
If safety is a priority and the shelf will be heavily loaded, it’s worth investing in metal expansion anchors as they provide stronger support.
Installation tips:
- Insert the anchors as deep as possible
- Attach the screws to the shelf according to the instructions
- Before final assembly, temporarily hold and adjust everything as needed
In my experience, this method securely holds Brimnes shelves on brick walls, even when fully loaded.
I always wonder why so many people insist on wall mounting IKEA shelves, even though these shelves are actually designed for free standing. Of course, safety is important, but has anyone ever considered whether these expensive heavy-duty anchors are really necessary?
If the shelf isn’t loaded heavily, I think it’s excessive to secure everything to the maximum. That doesn’t mean I’m careless, but sometimes safety is prioritized at the expense of effort and costs that might not be needed.
I’m curious if anyone here has experience with “simpler” fastenings and whether they have been noticeable in everyday use. Maybe my approach is a bit unconventional? 😉
On the topic: For brick walls, ordinary screws and basic anchors are often enough – the only thing that matters is drilling and aligning correctly.
karlau schrieb:
I’m interested to know if anyone here has experience with “simpler” fastenings and whether they have caused any issues in everyday use.Thank you for the thought-provoking perspective! I tend to prefer a solid but practical approach—I want to avoid unnecessary over-engineering as well as a solution that’s too loosely secured.
My main concern is safety during everyday loading, so I’m considering whether additional brackets or supports on the shelf should be used. I want to avoid any slight flexibility.
How would you assess the distribution of forces on the wall and shelf? Are individual brackets sufficient for fixing, or are multiple attachments definitely better?
karlau schrieb:
If the shelf isn’t heavily loaded, I think securing everything to the maximum extent is excessive.I understand your point, but when mounting shelves that will hold 10+ kg (22+ lbs) of books, I would prioritize safety to the fullest.
Zionbau schrieb:
How would you best assess the force distribution on the wall and shelf? Are single brackets enough for fixing, or are multiple ones definitely better?Multiple brackets are always better because they distribute loads and reduce tipping moments. Typically, you mount at least two brackets at the top per shelf. Especially for large Brimnes shelves, adding a lower support point can be useful when the shelf is loaded.
Proper positioning is also important! The brackets should be placed as close as possible to the shelf ends to ensure maximum leverage handling.
My advice: don’t screw the small brackets to the back of the shelf; instead, use sturdy metal brackets on the wall and work your way forward. This significantly improves stability.
Domau0 schrieb:
Several brackets are always better because they distribute loads and minimize tipping forces.Exactly! I have also always used two or three brackets and never noticed any downsides. More is better and it also gives you the confidence that everything is really solidly secured 😊
And don’t forget: always use a spirit level, otherwise the shelf will be crooked, which not only looks bad but can also unevenly increase the load.
