ᐅ How do you properly clean the surface of IKEA Platsa units?
Created on: 24 Jun 2021 08:37
Trali3
Trali3
24 Jun 2021 08:37
I recently assembled an IKEA Platsa system at home and would like to clean the surfaces in a sustainable and gentle way. My question is for anyone with experience in properly maintaining these specific furniture surfaces: How can the surface of IKEA Platsa be cleaned correctly without causing damage, unwanted shine, or scratches? Are there any recommended cleaning products to use, or is it better to avoid household remedies? Perhaps there are also suggestions regarding the appropriate cleaning frequency or tips on how to treat stains effectively without long soaking times or aggressive scrubbing. I look forward to well-informed answers that take the material (melamine/laminated wood) into account and include practical advice.
pinDavid
24 Jun 2021 09:12
For cleaning IKEA Platsa surfaces, I recommend simply using a soft, damp cloth with a little mild dish soap. Then wipe with clean water and dry. Do not use abrasive cleaners or harsh chemicals, as they can damage the surface.
AUSTINREN
24 Jun 2021 11:45
The surface of IKEA Platsa is typically made of melamine-coated particleboard, which offers good moisture resistance but remains sensitive to strong chemicals and mechanical stress.
For proper cleaning, I recommend:
- Using a mild water-based cleaning agent (e.g., dish soap).
- Avoiding abrasive sponges, brushes, or harsh cleaners to prevent micro-scratches.
- Wiping off stains immediately with a damp cloth to prevent them from penetrating the coating.
- Removing stubborn dirt with a lint-free cloth and a small amount of vinegar-water solution, but use sparingly and wipe thoroughly afterward, as frequent use of vinegar can damage the surface.
- Avoiding soaking the panels; instead, wipe them briefly with a damp cloth.
The recommended cleaning frequency depends on use and dirt levels, but regular light wiping is usually sufficient. This approach preserves the appearance and effectively protects the material.
Lamar
25 Jun 2021 07:23
What I find interesting about this discussion is that many people act as if you have to spend a fortune on special cleaners for IKEA furniture. Of course, it makes sense to avoid harsh chemicals, but the strong fear of cleaning with vinegar or occasionally using a microfiber cloth is often exaggerated.
pinDavid schrieb:
Avoid using abrasive or aggressive cleaners, as they can damage the surface.
That is true, but many common household cleaners are not as harsh as people think.
In my experience, simple household products and a microfiber cloth work well. If you become too obsessive, you might end up spending your whole life just cleaning.
In short: it’s fine to be pragmatic. If the surface doesn’t look like new after a few years of use, that’s normal. These pieces are not designer solid wood furniture.
Rodolfo
25 Jun 2021 18:09
I would like to add and clarify a few points here:
Melamine resin-coated surfaces, such as those on IKEA Platsa, are chemically quite resistant but mechanically sensitive to strong abrasion and sharp substances.
It is important not to soak the surface to prevent swelling damage to the underlying engineered wood.
For stain removal, a sponge or cloth with a mild cleaning agent is recommended. This can be, for example, a few drops of gentle dish soap in water.
After cleaning, rinse with clear water and immediately dry the surface with a soft, dry cloth.
Avoid using abrasive sponges, highly concentrated solvents (e.g., acetone), or alkaline cleaners.
A good remedy for grease or water stains can be a window leather or a lint-free cotton cloth.
If you prefer home remedies, I advise caution: vinegar water in high concentration over a long period can damage the coating.
In summary, cleaning should be mild, not too wet, and done promptly.
