ᐅ How to properly care for Ikea BRIMNES fronts?
Created on: 19 Apr 2023 10:38
Dobu58
Dobu58
19 Apr 2023 10:38
Hello everyone, I have a question that might interest some of you who use Ikea furniture: What is the best way to care for and clean the fronts of the Ikea Brimnes series?
It is important to me not to damage the surfaces, as the fronts often have a special coating. I also read that harsh or aggressive cleaners can damage the color or surface.
What are the best products and methods to use? What should you generally keep in mind when cleaning? Are there any specific tips to prevent scratches and keep the fronts looking good for longer?
I look forward to your experiences and recommendations, ideally with explanations of why certain methods are better than others. Thanks in advance!
farGlen
19 Apr 2023 11:03
I would say: use a soft, slightly damp cloth with a mild detergent. Afterwards, be sure to dry the surface thoroughly. Do not use harsh cleaners or abrasive materials, as the surface can be easily damaged.
CHENFAR
19 Apr 2023 13:29
For the care of Ikea BRIMNES fronts, I recommend the following:
- Clean with a soft microfiber cloth that is only slightly dampened.
- Use mild, neutral cleaning agents (e.g., pH-neutral soap solution).
- Avoid harsh chemicals and abrasive cleaners, as the coating is sensitive.
- After cleaning, always thoroughly wipe down with a dry cloth to prevent water spots and moisture penetration.
The fronts are usually made of coated wood-based material that should not get too wet. Moisture can cause swelling or warping. Therefore, steam cleaners should also be avoided.
Scratches can be minimized by not using rough sponges or similar items and by not placing sharp objects directly on the surface.
Gafiel
20 Apr 2023 09:15
CHENFAR schrieb:
For the care of the Ikea BRIMNES fronts, I recommend the following:
Exactly, these guidelines are quite accurate. I would like to add the following:
The BRIMNES fronts are made from an MDF panel with a melamine-coated surface. This melamine coating is durable but sensitive to certain solvents and mechanical stress.
Therefore, I recommend the following for optimal care and cleaning:
- Regularly wipe with a dry or slightly damp microfiber cloth to remove dust.
- For dirt, use a mixture of lukewarm water and a drop of mild dish soap, but never soak or leave wet.
- Immediate drying with a dry cloth is essential to prevent moisture from penetrating the edges or coating.
- Avoid abrasive cleaners or aggressive products such as ammonia, alcohol, or chlorine-based agents, as they can dull or damage the surface.
- To prevent scratches, furniture can occasionally be treated with a soft polishing cloth; however, special furniture wax is not necessary and may cause an unsightly film.
If you have children or pets in your household, I also recommend removing dirt as soon as possible to avoid discoloration or lasting marks.
I’m curious which cleaning products you have used so far and whether you have noticed any visible damage?
Dobu58
20 Apr 2023 10:55
Gafiel schrieb:
I’m interested to know which cleaning products you have used so far and whether you’ve noticed any visible damage?
Thank you for the detailed response! I have mostly used regular all-purpose sprays, but not ones specifically designed for coated surfaces, and sometimes sponges that are now probably too abrasive. No obvious visible damage or scratches have appeared yet, but I have noticed that the surface seems a bit duller over time, perhaps because I wiped it frequently with a damp cloth without properly drying afterward.
For this reason, I want to change my care routine and am looking for a sustainable method that will ensure both cleanliness and the preservation of the appearance in the long term. I will follow your advice, especially regarding immediate drying and gentle cleaning.
Are there any recommendations for how often to clean? Is it sufficient to dust regularly when dry and only clean spots as needed?
faso31
21 Apr 2023 08:47
Dobu58 schrieb:
Are there any recommendations regarding the frequency of cleaning?
That’s an important question—because cleaning too often or improperly can quietly damage the surface.
I suggest the following approach:
- Regularly (about once a week) dust with a dry microfiber cloth to remove abrasive particles that could cause scratches.
- Only treat stains or dirt when needed, using a damp cloth and a mild cleaner.
- Avoid constant moisture, meaning do not wipe with a wet cloth continuously without immediately drying afterward.
Also, you should be cautious with the cleaners you use: many all-purpose cleaners contain solvents or chemicals that are not suitable for melamine coatings and can weaken the surface over time.
I believe it’s a myth that you always have to clean everything immediately—careful judgment helps. If there are no food residues or greasy spots, dusting is usually enough.
How sensitive you consider the care depends on how heavily the furniture is used—whether there are children, pets, or intensive use in the household.
Are other surfaces in your home similarly sensitive? How do you handle their care?
