ᐅ How can you prevent screws from pulling out of Billy bookcases?
Created on: 12 Aug 2023 14:23
san63
san63
12 Aug 2023 14:23
I recently bought a Billy bookshelf from Ikea, and although I was careful during assembly, the screws keep loosening or even pulling out of the particleboard. So my question to the community is: what is the best way to prevent screws from pulling out in a Billy bookshelf?
I’m specifically talking about the holes in the particleboard, as I have often heard that screws don’t hold well in this material. Are there any special techniques for screwing, or should certain types of screws be used? Maybe pre-drilling, special anchors, or reinforcements?
What experiences have you had, and which solutions have proven effective to keep the bookshelf stable without having to constantly repair it? I look forward to your tips and any specific advice regarding the screws and the material used in Billy. Thanks in advance!
JORDON
12 Aug 2023 15:11
Hey san63,
first of all, great that you brought up this topic – Billy is definitely a classic, but I guess everyone knows those little annoyances 😊.
About the problem: particleboard panels aren’t the most durable. My tip is to always pre-drill! This prevents the wood from swelling or cracking. Also, I usually put a drop of wood glue into the hole before driving in the screw – it helps with a better grip.
I’ve also noticed that the screws provided are often quite thin. It’s worth switching to slightly thicker screws, but not too thick, otherwise the wood might split again.
And if the shelf is moved around or loaded frequently, you could stick some fabric tape or small wood strips as reinforcement on the back panel – kind of a “safety net” for the screws.
san63 schrieb:
particularly durable. Are there special screwing techniques?
Exactly, technique really makes a difference. Otherwise, you’ll quickly end up with degraded holes ;-)
Lotizar
12 Aug 2023 16:04
Additional Information:
The biggest issue with Billy shelves is the particleboard, which can tear if screws are overtightened or handled incorrectly. The technical term for this is "tearing out of the engineered wood panel."
Here are some precise tips:
1. Pilot Holes: Drilling pilot holes is important, but the drill bit diameter should be slightly smaller than the screw diameter so the screw grips properly in the wood.
2. Screw Quality: It is advisable to use high-quality particleboard screws – they usually have a special thread that displaces less material, reducing the risk of tearing out.
3. Tightening: Do not fully tighten the screws. Tighten them enough to make the structure stable but not so much that the wood is damaged.
4. Use Inserts: For heavily loaded areas, special sleeves or metal inserts can be used to prevent the screw from biting directly into the particleboard.
In my experience, points 1 and 3 are particularly effective in reducing the problem. For critical load-bearing points, I also recommend considering additional structural elements.
JORDON schrieb:
Always drill pilot holes! This prevents the wood from swelling or splitting.
Exactly. Drilling pilot holes is practically a must.
TEBILO
13 Aug 2023 10:17
I tend to approach these topics in more detail because the screws coming loose in Billy units often depend on the specific load and the screw locations.
1. Material check: The typical wood-based panels used in Billy are relatively soft, which means screws hold less effectively than in solid wood. Pre-drilling is definitely recommended, using a drill bit slightly smaller than the screw shaft, not the thread.
2. Type of screws: Are you using the original Ikea screws or others? In my experience, even high-quality particle board screws with coarse threads provide better grip, as they cut into the material more effectively.
3. Load situation: Where exactly are the screws coming loose? On the sides, in the back panel area, or at the shelves? Depending on the location, reinforcement brackets or metal plates for load distribution could be added.
4. Assembly method: Drive screws in slowly and avoid overtightening. This prevents the surface from cracking and the wood from splitting.
5. Alternatives: If screws frequently come loose, it’s also worth using small dowels (e.g., wooden or plastic dowels) to stabilize the material. This is especially helpful if shelves are often assembled and disassembled.
One more question for san63: Do you mainly use the shelf as a stationary unit, or is it moved frequently? Have you already tried using different screws or reinforcements?
san63 schrieb:
Are there special techniques for screwing, or should certain screws be used?
That’s the key point. 😉
Lotizar schrieb:
You tighten them so that the carcass is stable but not so much that the wood gets damaged.
I can only confirm that—the right balance is crucial here.
neoren
13 Aug 2023 11:42
Pre-drilling is mandatory.
Remove dust from the hole.
Do not overtighten screws.
Use smaller screws for weak material.
Reinforce with wood glue if necessary.
