ᐅ How do you prevent mold growth behind KALLAX units placed against exterior walls?
Created on: 8 Oct 2022 08:27
keosar
keosar
8 Oct 2022 08:27
Hello everyone, I have a problem in my apartment where mold keeps forming behind my KALLAX shelf, which is placed directly against a cold exterior wall. So far, my solution has been to occasionally pull the shelf away and ventilate the wall, but this is not a practical long-term measure. Does anyone have experience or tips on how to permanently prevent mold behind KALLAX furniture on exterior walls? I am especially interested in practical solutions that work with the typical indoor humidity and room conditions found in rental apartments. Are there any special tricks, for example regarding air circulation or insulation between the furniture and the wall, that help in the long run?
Tinaneo
8 Oct 2022 10:13
In my opinion, the problem is often caused by a combination of poor air circulation and high humidity. To avoid mold permanently, it usually isn’t enough to just wait or ventilate occasionally. But I wonder: have you ever checked the exact humidity levels behind the furniture? Some say 60% relative humidity is the critical limit, but in the space behind the furniture it can be much higher. Without measurement, any advice is only half-hearted. A constructive approach could be to improve the climate with a permeable backing panel or ventilation slots in the KALLAX unit. I am also skeptical about the common recommendation to move furniture further away from the wall – that isn’t always possible in small rooms. Does anyone here have solid experience with special wall sealing or insulation materials between furniture and exterior wall?
Siflo
8 Oct 2022 12:45
When preventing mold behind furniture placed against cold exterior walls, the combination of sufficient air circulation and controlled humidity levels is crucial. A gap of at least 3-5 cm (1-2 inches) from the wall is necessary to allow air to circulate. Additionally, I recommend using humidity sensors to monitor critical levels. Indoor humidity in living areas is often significantly too high in winter (above 50%). Regular airing out by fully opening windows for 5-10 minutes three times a day works wonders. Special insulation panels with a vapor-permeable structure behind the furniture can reduce the temperature difference, preventing condensation. Important: the wall itself should remain dry, so impermeable plastic sheets as a backing are not suitable because they trap moisture. The back of the furniture can be improved with perforated panels or battens to support air exchange and avoid moisture buildup.
BLAKEO
8 Oct 2022 14:02
Tinaneo schrieb:
Does anyone here have reliable experience with special wall waterproofing or insulation materials placed between furniture and an exterior wall?
I would like to expand this question a bit: some furniture is built very solidly from the factory, while KALLAX is relatively thin. Because of this, a cold surface often forms behind the wall. One idea would be to use a thin insulation panel, for example made of polystyrene or mineral wool, directly on the wall behind the furniture to provide some insulation. However, the question arises whether this would restrict vapor permeability—in other words, whether moisture can still evaporate. I am skeptical about airtight solutions.
Instead, I advocate for better air circulation. A simple but perhaps inconvenient solution is to move the furniture 5cm (2 inches) away from the wall and install a few ventilation holes or slats between the back of the furniture and the wall.
What is your opinion on an active solution, such as a small electric ventilator behind the furniture? It might be over the top, but it would be interesting to know if this could help control moisture removal.
jodeo58
8 Oct 2022 14:45
I always recommend keeping a gap (at least 5cm (2 inches)) and regular shock ventilation. Additionally, air circulation can be improved with small wooden strips on the back of the furniture. Avoid using any foil materials. This is usually sufficient.
SauDietmar
9 Oct 2022 09:38
Here is a short guide for anyone facing this issue:
1. Check the location: Exterior walls are often cold and can cause condensation.
2. Create space: Furniture should stand at least 5 cm (2 inches) away from the wall.
3. Optimize ventilation: Ideally, install a slatted construction like a bed slat frame behind the KALLAX or at least ventilation slots.
4. Measure humidity: Regularly monitor the indoor humidity with a hygrometer.
5. Adjust room climate: Maintain indoor humidity below 60% continuously.
6. Insulation: If possible, attach a thin, vapor-permeable insulation panel (e.g., wood fiber boards) to the wall behind the furniture.
Common mistakes:
- Placing furniture too close to the wall.
- Sealing the back panel with plastic foil or paint.
- Lack of regular ventilation.
In summary, air circulation and humidity monitoring are crucial. A passive solution (space, ventilation) is usually the most effective and simplest.
