Hello everyone, I recently assembled several IKEA Brimnes furniture pieces, especially dressers and wardrobes. After putting them together, my family and I noticed that some parts wobble quite a bit when touched or under light pressure, which doesn’t feel very stable.
My question is: What practical techniques, tools, or additions can be used to prevent IKEA Brimnes furniture from wobbling? I’m particularly thinking about properly tightening the screws, possible additional stabilization methods, or useful tips to keep in mind during assembly. Are there any known weak points in the design to watch out for?
I would really appreciate any helpful advice.
Regarding the stabilization of IKEA Brimnes furniture, it should be noted that these products are designed with a modular system, which provides flexibility but also results in weaker connection points. Common weak spots are often the back panels, dowels, and screw connections on the side panels. To prevent wobbling, these areas should be carefully checked and reinforced if necessary. A proven method is securing the furniture to the wall using the supplied wall brackets or angle brackets. It is also recommended to check the floor surface and, if needed, adjust the furniture feet. It is advisable to retighten all fasteners after a few weeks, as they can loosen with use. Wood glue is only partially effective because the furniture is partly made of coated particleboard, to which glue adheres poorly. Alternatively, washers under screws can provide better grip. In summary: wall anchors, back panel fastening, a level floor, and regular inspections are the key measures.
Deandre schrieb:
The back panel provides the furniture structure with significant lateral stability.Thank you for the advice, I had underestimated that. In fact, I initially removed the back panel loosely to route cables, and I probably didn’t pay enough attention to securing it tightly afterward.
RENMA schrieb:
Wall anchors, back panel fastening, level subfloor, and regular inspections are the main measures.That helps me a lot; your recommendations sound quite feasible. Tomorrow, I will carefully check the back panel and screws, and if necessary, use furniture feet pads or small wedges to compensate for any uneven flooring.
I always find it funny how everyone suddenly turns into a handy person when assembling furniture 😄. But seriously: you should also give the furniture some time to settle. For example, if you screw a dresser tightly together but still leave everything movable, any wobbling can be caused by material tension. My simple rule of thumb: assemble the furniture, then let it rest for a day or two and possibly tighten the screws again afterward. If you place a thin rubber strip between the back panel and the furniture, you can even reduce small vibrations. So, a little patience can sometimes go a long way.
One more straightforward tip to finish: If any wobbling persists, you can install additional angle brackets in particularly stressed areas. These are available at hardware stores and significantly improve stability. This is especially useful for cabinets that are frequently opened and loaded. It is important not to replace the original screws but to use the brackets as an addition.
