ixabdurrah23 Sep 2024 13:27Hello everyone,
I am currently dealing with a problem that many people probably know: How can you prevent color fading over time in furniture like the Malm series, especially in the colored versions?
It is important to me that we not only talk about simple tips like avoiding direct sunlight but also about other factors specifically relevant to Malm furniture, such as the type of surface coating, cleaning instructions, and possible protective products.
I am also interested in how different light sources (UV content, LED, halogen) affect color stability and whether there are effective protective measures that can be used in everyday life without damaging or altering the piece of furniture.
Does anyone have practical experience or even scientific background on this? It would be great if you could share your tips with brief explanations so I can understand them well.
Thank you in advance!
Hello ixabdurrah,
First of all, you’re addressing a very interesting topic! Color fading in Malm furniture is primarily caused by UV radiation and prolonged exposure to intense lighting. Malm typically has a veneer surface or a lacquer finish, which is sensitive to light and environmental factors.
An important aspect is the surface material: In the standard lacquer coating on Malm, UV rays act as a catalyst for the breakdown of color pigments. Therefore, a UV protection film or a special sealing is highly recommended if you want to slow down the fading process.
Regarding light sources, LED lamps with low UV output are generally the gentlest option. Halogen lamps, on the other hand, emit more UV and should be avoided near colored furniture. Unfiltered daylight through windows is usually the biggest risk.
I would suggest avoiding harsh or aggressive cleaning agents, as they can damage the lacquer protective layer. Instead, use a soft microfiber cloth and mild cleaning products designed specifically for lacquered surfaces.
Another tip is to use furniture care products with UV protection, which can be applied regularly. These form an additional protective layer and noticeably extend color intensity. If you want to repaint the furniture, there are special UV-resistant paints that offer longer-term protection against fading.
Finally, do you have your Malm furniture indoors or outdoors? The environmental conditions definitely have a strong impact on color changes.
I hope this helps – I’m happy to provide more detailed information on specific points if needed!
Hello ixabdurrah and all interested parties,
I would like to delve a bit deeper into the discussion started by Filippo and SETHBLA. In my view, when it comes to Malm furniture, not only direct UV protection is important, but also a holistic approach to handling the piece.
That sums it up perfectly. Whether veneer or lacquered versions, the pigments are vulnerable to decomposition caused by UV light and oxygen without protection.
A step-by-step approach I recommend is:
1. Position the furniture so that it is exposed to as little direct sunlight as possible. If this is not feasible, UV-protective films or curtains can help.
2. Use only mild, pH-neutral cleaning agents. These protect the surface and thus the color from premature fading in the long term.
3. If needed, apply a UV-protective polish specifically designed for wood and lacquered surfaces.
4. Regularly check the surface condition for scratches or wear, as damaged areas fade faster due to lack of protection.
5. For heavily used areas, occasional repainting with a UV-resistant clear coat is possible and significantly extends the color’s lifespan.
You also asked whether different light sources affect colors differently. Indeed, UV filters on windows and lamps are the safest way to prevent changes in color tone.
How is the furniture currently protected or positioned? That would help make more targeted suggestions.
Best regards!
Filippo schrieb:
“In standard Malm finishes, UV rays act as a catalyst for the breakdown of color pigments.”
SETHBLA schrieb:This is very important; LEDs are significantly better than halogen or even some older fluorescent tubes.
“Use LED lighting, which contains little UV.”
Best regards!
