I would like to personalize my Ikea Brimnes furniture a bit and am wondering what the best way is to modify it myself. In particular, I am interested in which materials and tools are most suitable to rebuild the furniture so that it remains sturdy and visually appealing.
Are there any proven techniques, for example when attaching new handles, applying paint, or adding extra elements like shelves or lighting? I would also like to know if there are specific challenges when working with the surface that one should be aware of to ensure the result is durable.
Who has experience and can offer tips on how to modify Ikea Brimnes furniture yourself without compromising its structure or functionality? Thanks in advance!
Hello man54,
I read your question about modifying Ikea Brimnes furniture and would like to provide a structured guide.
1. Preparation: Remove all movable parts such as handles and drawers. Clean the surfaces thoroughly to remove dust or grease.
2. Sanding: Brimnes furniture has a melamine-coated surface. Since it is smooth, lightly sand it with fine sandpaper (grit 220) to help paint or adhesive stick better.
3. Paint/Finishing: It is best to use acrylic or chalk paint. Acrylic paint is more durable, while chalk paint is easier to distress and works well for vintage looks.
4. Changing handles: Remove old handles and screw in new ones at the appropriate spots with pre-drilled holes. Use a drill with a small bit diameter to avoid damaging the wood.
5. Additional elements: For LED lighting, you can use self-adhesive strips that are thin and produce little heat, making them easy to hide, for example behind shelves.
6. Protection: After painting, a matte clear coat is recommended as a sealant to prolong durability. In general, you should protect against moisture.
A common mistake is not sanding the surface, causing the paint to not adhere or dry unevenly.
I hope this guide helps you.
sinhau schrieb:
A common mistake is not sanding the surface, which causes the paint not to adhere or to become uneven.Exactly, that’s an important point. I would like to add:
- When sanding, avoid using too coarse a grit, as this can damage the melamine coating.
- For drilling new holes in Brimnes furniture, it’s best to use a drill bit with a depth stop to prevent drilling too deep.
- If you want to install shelves or additional components, it’s helpful to create simple groove or dowel holes in the back panel or sides for flexible installation.
- Regarding paint choice: water-based paints are usually better for indoor furniture because they contain fewer harmful substances.
Summary:
- Clean and sand surfaces
- Pre-drill holes carefully
- Use high-quality paints
- Seal after painting
- Attach additional elements with sturdy fasteners
This will preserve functionality and help the furniture last longer.
Hello man54,
This is a very well thought-out question, as you can see from the level of detail. I would like to add a practical tip: If you want to change the color of the Brimnes furniture, it often works best to use chalk or painter’s tape as a masking aid to keep the edges clean.
In general, I also recommend modeling new elements like small shelves beforehand on cardboard or stiff paper. This way, you can check in advance if the proportions are right.
If you want to integrate lighting, look for thin, flexible LED strips. I have had good experiences with these and use the strips on the underside of shelves.
And very important: Always tighten the screws gently with a suitable cordless screwdriver; overtightening can loosen the wood panels. If you have any further questions, just ask.
