ᐅ What is the best way to childproof BILLY?
Created on: 23 Apr 2016 17:32
Likim
Likim
23 Apr 2016 17:32
Some time ago, I bought a Billy shelf from IKEA, and now I need to secure this piece of furniture to make it completely safe for small children.
My question is: What is the best way to make BILLY childproof? I am thinking about possible anti-tip measures, preventing finger traps, and securely storing items at the child’s height. Are there any proven methods or accessories specifically designed for this purpose?
I look forward to your tips and experiences!
GIBAPO
23 Apr 2016 18:11
To secure a BILLY shelf, I generally recommend the following measures:
1. Attach the included wall mount to safely prevent the shelf from tipping over.
2. Use corner protectors made of foam or soft plastic on the edges to avoid injuries.
3. Store small, swallowable parts in closed boxes or compartments, ideally on higher shelves.
It is important to regularly check the safety measures to ensure they function properly, especially when children are very active.
FABIAN_DEO
23 Apr 2016 19:04
In addition to the points mentioned, I would like to add the following:
To truly make BILLY childproof, it is advisable to install special tilt-locks that not only secure the back panel but also firmly anchor the furniture to the wall. I have had good experience with metal anchors that are installed deep into drywall or masonry walls.
It is also important to regularly tighten all screws, as they can loosen over time with frequent use. Another tip is to use self-adhesive child locks for drawers to prevent children from opening them unsupervised.
Finally, I recommend not storing heavy items on the top shelf that could cause injury if they fall. What the furniture is used for (e.g., books, toys, or decorations) is also an important consideration.
Could you share a bit about your living environment? Wall type, age of your child, for example? This helps with more specific advice.
Likim
23 Apr 2016 19:28
FABIAN_DEO schrieb:
Could you tell us more about your living environment? Wall type, age of your child, for example?
Good idea, thanks! My child is 2 years old, very curious, and just starting to climb. The walls are mainly drywall (plasterboard) on a wooden stud frame, and the ceiling height is 2.5m (8 ft 2 in).
I installed the standard wall mounts from IKEA, but they don’t seem sufficient given my child’s current activity—he likes to pull on and climb the furniture. That’s why I’m asking if there are more robust, possibly semi-professional solutions to make the shelf truly tip-proof.
REN40
24 Apr 2016 08:07
In your case, especially with drywall (plasterboard) walls, special anchors and fittings designed for drywall are absolutely necessary. Cheap plastic anchors hardly support the weight required to securely mount a shelf, especially if a child pulls on it.
I recommend using hollow wall anchors or toggle bolts, which expand behind the wall and provide strong load-bearing capacity. Additionally, you can use metal brackets to further secure the shelf by attaching it to the wall at the top.
Furthermore, child safety locks for the cabinet doors are advisable if the BILLY shelf comes with doors or flap doors. This prevents children from reaching inside or breaking off the wooden strips.
ixfra
24 Apr 2016 09:12
Hey, great topic! 🙂 I understand how frustrating it is when little ones want to explore everything and safety is the top priority!
For me, installing special furniture fasteners, which you can get at hardware stores, worked really well. They’re easy to install and can prevent tipping.
I also equipped the lower shelves with childproof boxes to keep things from falling out and covered sharp corners with edge protection tape – it comes in various colors and is almost invisible!
The most important thing is to stay consistent; it’s worth it! Good luck! :-)
