ᐅ How can you restore Ikea BRIMNES furniture to look "like new" again?
Created on: 2 Jan 2019 09:13
davonHello everyone,
I have some Brimnes furniture from Ikea that now looks quite worn – especially the white surfaces show signs of use, small scratches, and in some places a slightly yellowed appearance. I’m interested in how to best make these pieces look “like new” again.
I’m not just looking for surface cleaning, but also if there are any special cleaning products, home remedies, or maybe even small repair tips to refresh these white frames and fronts or possibly make minor damage less visible.
Who has experience or advice on what really works for BRIMNES furniture – especially regarding scratches and color changes? Thanks in advance!
davon schrieb:
I’m interested in how to restore these pieces of furniture to look “like new.”It’s interesting to consider whether there really is a universal “like new” solution. Ikea produces in large quantities and tends to use affordable materials and finishes that aren’t necessarily designed for long-term durability.
Maybe the problem lies in the material itself, and trying to fix it is just a temporary patch? I believe professional surface treatment or even replacement of Ikea furniture makes more sense than lengthy repair attempts. The effort and the outcome are usually not proportional.
But I’m curious to hear others’ opinions—perhaps there are clever tricks I haven’t thought of.
For cleaning and minor repairs on BRIMNES furniture, I recommend the following:
- For light dirt, mild cleaning agents like dish detergent with warm water are usually sufficient. Wipe with a soft cloth; do not use abrasive sponges.
- For scratches on coated surfaces, special furniture touch-up markers or wax sticks can sometimes help camouflage small blemishes in color.
- Yellowed areas can possibly be refreshed by gently rubbing with a damp cloth and a vinegar solution, but please test this in an inconspicuous spot first.
If you like, I can also share a brief polishing method that can make some surfaces appear smoother again.
GALEO4 schrieb:
Maybe the problem already lies in the material itself, and people are just trying to force it to work?I share that concern, but I think it’s important not to give up too quickly. I doubt that simple cleaning or polishing can really restore a significantly damaged plastic or film coating to look “like new.”
First, it’s necessary to identify the exact material used for the surface coating (melamine resin-coated particleboard?). Only then can a more targeted approach be taken, such as using gentle abrasives or even applying a thin layer of paint if the surface is severely damaged.
Unfortunately, there is a lot of guesswork involved here, since Ikea rarely provides detailed information about the materials used.
From a technical perspective, the surface of Ikea BRIMNES furniture is usually made of melamine-coated particleboard. This surface is highly resistant to scratches but not completely immune. Here is a targeted approach to refurbishing the furniture:
- Cleaning: Start by treating the surface with a pH-neutral cleaning agent to remove dirt and grease.
- Scratches: Small superficial scratches can be concealed using a special furniture repair pen designed for melamine surfaces. Alternatively, correction pens intended for laminate can be used.
- Yellowing: This usually requires very careful mechanical removal of surface deposits, for example with fine abrasive pads, followed by cleaning.
- Repair: For deeper damage, replacing the damaged parts is usually the best solution, as refinishing will not restore the original surface texture.
Be cautious when using chemical agents such as acetone, as they can severely damage the surface.
lukin schrieb:
For scratches on coated surfaces, special furniture markers or wax sticks can sometimes helpI can fully confirm this tip. In any case, always test the matching color tone before use.
Additionally, I have successfully used fine-grit sandpaper (for example, 1000 or 2000 grit) on a BRIMNES cabinet to gently smooth out light scratches. Afterwards, apply a polish designed for plastic surfaces.
This significantly refreshes the appearance without affecting the color tone. However, it is important to proceed very carefully to avoid damage.
