ᐅ How do you remove leftover anchor fragments from Kallax hinge holes?
Created on: 9 Nov 2022 08:36
Diezekiel
Diezekiel
9 Nov 2022 08:36
I recently installed hinges on an IKEA Kallax shelf, which required drilling dowels into the shelf. Unfortunately, during disassembly, some dowel pieces broke off inside the hinge holes and are now stuck. These remnants are causing issues because I want to reinstall the hinges accurately, but the holes are not properly cleared. My main question is: How do you reliably remove dowel fragments from the Kallax hinge holes without damaging the edges of the holes? What tools or techniques would you recommend for removing the debris so that the holes are clean and fully functional again? A detailed guide or tips on potential pitfalls would be very helpful, thank you!
jeff65
9 Nov 2022 09:15
If dowel remnants get stuck in the hinge holes of Kallax shelves, removing them often requires patience. First, it’s worth trying to lift and pick out the remnants using a sharp needle or a thin push pin. Be careful not to damage the edges of the holes. If the dowel is made of wood or plastic, you can cautiously and gently try to unscrew the material using an appropriate spiral drill bit without enlarging the hole. In any case, it makes sense to clean the holes slightly from the inside with fine sandpaper afterwards to remove loose fibers before inserting new dowels.
Tommy38
9 Nov 2022 12:42
I had a similar issue with Kallax hinges. Here is my advice: First, try to gently pry out the remaining dowel pieces with a thin screwdriver – but be very careful not to cause any damage. If that doesn’t work, a narrow metal hook (for example, a straightened paperclip) can help lift out the remnants. After removing the leftovers, I recommend smoothing the inside of the hole with a fine sanding stick or a small piece of sandpaper. It’s important to know that Kallax shelves are made from fiberboard, so you need to be very gentle to avoid splitting. If the holes have become too wide, it can help to use a slightly larger dowel or to reinforce the hole with wood glue and small wood chips.
BOMILAN
9 Nov 2022 14:23
A small tip: Using a wire brush attached to a cordless drill can quickly remove leftover wall anchors. Be careful not to enlarge the hole. If you don't have a wire brush available, a sharp needle will also work.
cassandra
10 Nov 2022 10:05
Tommy38 schrieb:
If the holes have become too wide, it helps to use a slightly larger wall plug or improve the hole with wood glue and small wood chips.
This is an important point.
Additionally, I recommend using a special wall plug extractor or a small chisel combined with a microscope or magnifying light to precisely remove any residues. It is also important to check the material of the wall plug – plastic residues can be gently heated with a soldering iron and then removed more easily.
Important: When refining the holes, do not enlarge beyond the original core hole, as this will compromise the stability of the shelf. Using a thin but sturdy metal spatula can also help without damaging the edges.
