ᐅ What is the best way to gently clean stains from Malm furniture?
Created on: 10 Nov 2021 09:27
ParsanI have noticed some stains on my Malm furniture for a while now, especially on the light-colored surface. Since this furniture is often made of coated wood or particleboard, I want to clean it as gently as possible without damaging the surface. My question is: How can you gently clean Malm furniture to remove stains without harming the coating or dulling the finish? Are there any special cleaning products or home remedies that work particularly well, or is it better to stick with simple solutions like mild dish soap and water? I would appreciate practical tips for cleaning and maintenance to keep the furniture looking good for a long time and effectively remove the stains.
Hey Parsan! 🙂 Your question is really important because Malm furniture doesn’t respond well to all cleaning methods. I’d recommend starting with a damp, soft cloth and mild dish soap. Never use abrasive cleaners or rough sponges, as they can quickly damage the surface.
For stubborn stains, you can carefully try adding a splash of vinegar to the water, which often helps with grease spots. But be careful not to use too much vinegar, as it can harm the finish.
If you’re like me and enjoy experimenting a bit: applying toothpaste to the stain, gently rubbing it in and then wiping it off thoroughly has sometimes worked wonders on dark stains! But always test on an inconspicuous area first. 😉
So: be gentle, patient, and avoid harsh treatments! Good luck!
Hello Parsan, I’d like to add to dijan’s helpful tip: Malm furniture usually has a melamine resin coating, which is very sensitive. It’s important not to use cleaners containing alcohol or solvents – these can damage the surface and cause it to lose its shine.
I recommend using a fine-pored microfiber cloth, as it is gentle and absorbs dirt well. Stains like coffee rings or fruit marks should ideally not be allowed to dry. Instead of vinegar, you can also choose special furniture cleaners designed specifically for coated surfaces.
After cleaning, you can gently polish the surface with a dry cloth to maintain its shine. If you want, I can gladly send you a list of recommended cleaners.
dijan schrieb:
Apply toothpaste to the stain, gently rub it in, and then wipe it off thoroughly That’s interesting—I wouldn’t have thought of that! What exactly do you mean by the toothpaste? Just a small amount, let it sit for a short while, and then wipe it off with a damp cloth, right?
And thanks for the tip about vinegar; I initially thought it was a good home remedy, but too much might be harmful.
Takutau schrieb:
It’s important not to use cleaners containing alcohol or solvents So it sounds like I need to check the ingredients carefully beforehand. What do you think about so-called all-purpose cleaners? Some advertise as being “safe for all surfaces.” Is it better to avoid them, or can they be tested in a diluted form?
I always find it interesting how many people rush to try all kinds of cleaners without first considering the cause of the stains. Are these water stains, grease marks, coffee residues?
Some stains actually only develop or worsen due to incorrect cleaning or excess moisture.
My advice: If you use a product, test it first! The living room or kitchen is not a lab, so apply a small amount and observe the effect.
Sometimes, overly aggressive cleaners cause more long-term damage than a slightly visible stain.
And of course, toothpaste on furniture – wonderfully creative! 🙂
Parsan schrieb:
Better to avoid it, or can it be tested in diluted form?
