ᐅ How to fix squeaky Ikea HEMNES furniture?
Created on: 19 Nov 2024 07:38
Dimitri8
Dimitri8
19 Nov 2024 07:38
I have a few IKEA Hemnes furniture pieces at home, including a wardrobe and a bed. Lately, they have been squeaking during use, especially when moved or under load. The squeaking usually comes from the hinges and joints, but I’m not sure if the cause might also be related to the wood itself.
Does anyone have experience with reliably fixing these annoying squeaks without damaging the furniture? Which methods actually work well for Hemnes, and what should you keep in mind to ensure the squeaking is not just temporarily gone but eliminated long-term?
I would also appreciate tips on proper maintenance and any recommendations on lubricants or other aids that IKEA or others suggest when furniture starts to squeak.
neoren
19 Nov 2024 08:21
For squeaky HEMNES furniture, it usually helps to retighten all the screws. After that, you can spray the hinges with a little WD-40 or silicone spray. This reliably prevents squeaky metal contact.
Nabla64
19 Nov 2024 09:53
To specifically address squeaking in HEMNES furniture, I recommend the following steps:
- First, systematically check all screws and connectors to ensure they are tightly secured and tighten if necessary. Loose parts often cause squeaking noises.
- Next, clean the hinges. Dust or dried lubricant residues can cause noise.
- Then, treat the parts with a suitable lubricant, such as silicone spray, since it does not damage the wood or hardware. For wood joints, use graphite powder or a dry lubricant, as liquids can cause the wood to swell.
- If the squeaking comes from the wood itself (for example, due to friction between two wooden surfaces), applying furniture wax or paraffin helps reduce friction.
Important: Avoid using oils that become sticky or attract dust.
In some HEMNES models, the connection of the back panel or shelves may also become loose occasionally—these areas should be checked as well.
Dilen
20 Nov 2024 10:14
neoren schrieb:
Tightening all screws usually helps with squeaky HEMNES furniture.
That’s a good first step, but for a lasting solution, a closer look is advisable.
Specifically: HEMNES furniture is made from solid wood, which reacts to humidity and temperature. Wood naturally expands and contracts, causing stress at the joints. This can lead to screws loosening again, so a combination of mechanical reinforcement and proper care is recommended.
If the hinges squeak, it’s best to remove them entirely, clean them (e.g., degrease with a soft cloth and some alcohol), and then apply a dry lubricant like graphite powder or a high-quality silicone spray. This reduces friction over time.
For the wood itself where there is rubbing, furniture wax or paraffin oil can help. It is important not to apply too much to avoid swelling or discoloration.
Pay particular attention to areas where wood meets wood or metal meets wood. Sometimes rubber or felt pads placed between wooden parts or as cushions can also help.
Which furniture items are squeaking for you exactly? Only cabinets, or also the bed frame? How old is the furniture and how heavily is it used daily? This information helps provide more precise advice.
In general: a thorough maintenance every few years is recommended to prevent these noises early on.
dijan
20 Nov 2024 14:22
Dilen schrieb:
For the wood itself, furniture wax or paraffin oil helps with friction.
I can only agree! My HEMNES wardrobe was squeaking exactly at one edge, and a little furniture wax quickly stopped the annoyance.
A small tip: when applying the wax, follow the wood grain to keep the treatment discreet.
Also, don’t worry if it doesn’t disappear immediately – sometimes it takes a few days for the wax to fully absorb and reduce the friction.
Besides, a bit of fun with DIY can make the whole process much less bothersome!
likuken
21 Nov 2024 11:07
Dimitri8 schrieb:
I have a few IKEA HEMNES furniture pieces at home, including a wardrobe and a bed. For some time now, they have been creaking during use, especially when moved or loaded. The creaks mostly come from the hinges and joints, but I’m not sure if the cause might also lie within the wood itself.
I think the problem goes deeper than just the surface or tightening screws. Although HEMNES is solid wood, IKEA produces in large quantities – quality variations are always possible.
In my opinion, short-term solutions like lubricants rarely help if the wood builds up internal tension or the joints have shifted slightly.
One might consider stabilizing the furniture long-term with special adhesives (wood glue) or reinforcing the joints with additional screws. But be careful not to damage the furniture in the process.
For those who prefer to wait, applying less sudden stress to the furniture can help avoid rapid wear. And yes, occasionally retightening the connectors is a permanent maintenance task.
Whether the effort is worthwhile depends on the value and usage – sometimes buying new is the more rational choice. But of course, that’s a matter of personal preference.
