Hello everyone, I have a question that has been on my mind for some time: How do you fix squeaking hinges on an IKEA Brimnes piece of furniture?
Specifically, it’s about a Brimnes wardrobe model with two doors, where the hinges increasingly squeak loudly and annoyingly when opening or closing. I suspect it might be due to a manufacturing defect or dryness, but it could also be caused by dirt or improper installation.
I have considered whether lubricants might help, but I am unsure which product is suitable to avoid damaging the hinges or leaving stains on the wood. Maybe someone knows the exact type of hinge or materials used and has experience with repairing them.
Are there any experts here who can offer advice on the proper procedure? Possibly a step-by-step guide or tips on common mistakes when lubricating or cleaning?
Thanks in advance for your help!
Hello Bauenes,
I can help you with this because squeaky hinges are indeed a common issue with IKEA furniture, especially the Brimnes series. Here is a simple guide to systematically address the problem:
- Step 1: Clean the furniture
First, take a close look to see if the hinge mechanism is dirty or has particles stuck inside. You can clean it carefully with a clean cloth and, if necessary, a bit of mild rubbing alcohol.
- Step 2: Inspect the hinges
Open the door and check if the screws are tight. Loose screws can cause noise. Tighten them with a suitable screwdriver but not too much, to avoid damaging the material.
- Step 3: Use lubricant
For Brimnes hinges, I recommend a spray oil or silicone spray. Avoid grease or petroleum jelly, as they can attract dirt and may also stain the wood.
- Step 4: Apply
Spray the lubricant directly onto the moving metal parts and then open and close the door several times to help the oil spread evenly.
Common mistakes:
- Applying too much lubricant on wood or visible surfaces.
- Skipping the cleaning step.
- Ignoring the screws.
I hope this helps you so far! If you need more detailed information about the type of hinge, feel free to ask again.
Best regards!
- Step 4: Apply
Common mistakes:
Best regards!
taudi schrieb:
For the Brimnes hinges, I recommend a spray oil or silicone spray.That is basically correct, but I would like to add that the hinges on Brimnes are very standardized, usually made of galvanized steel with a plastic coating.
To eliminate the squeaking noise as effectively as possible, I would recommend the following:
- Carefully remove the door by loosening the mounting screws.
- Use a dry cloth to remove dust and old lubricant residues from the hinge bearings.
- Apply a fine sewing machine oil or a special sliding lubricant that penetrates deep into the bearings.
- Avoid greasy substances like WD-40 as a permanent lubricant, because they tend to attract dirt quickly or dry out.
- After oiling, reinstall the door and align it carefully, as incorrectly fitted hinges can cause tension and loud noises again.
Regarding troubleshooting:
Many underestimate that squeaking can also be caused by material wear in the guide roller or a slightly altered angle in the hinge. Looking at the bearing points with a magnifying glass often helps to spot small cracks or signs of wear.
Have you checked if certain positions during opening or closing are especially noisy? This is often a good clue to the exact problem area.
Finally: Patience is important – apply lubricants sparingly and reapply after a few days if necessary.
baAlejandr7 Jun 2022 09:27Gafiel schrieb:
Many underestimate that squeaking noises can also be caused by material wear in the guide roller or by a slightly altered angle in the hinge.Very good point, I’d like to add the following:
When repairing, long-term maintenance is also important. One-time lubrication is not always sufficient—especially for frequently used furniture like the Brimnes wardrobe.
My tip: Check the hinges every three months for dirt and, if necessary, lubricate them again with the same lubricant. It is also advisable to always apply even load on the door hinges, meaning not to open or close the doors too quickly, as this leads to increased wear.
If you have installed a hinge type with a damper, you should additionally check whether the damper is still functional, since a damaged damper can also change the noise.
In conclusion: To protect wooden surfaces, never spray lubricating oil directly onto visible wood and ideally wipe it off immediately with a paper towel.
