ᐅ How do you fix loose screws in Ikea BRIMNES furniture?
Created on: 10 Feb 2017 14:37
reogo
reogo
10 Feb 2017 14:37
I have noticed that several screws in my Ikea Brimnes bed have become loose over time, causing some parts to shift slightly and making the furniture overall seem unstable. Since I would like to find a permanent and secure solution, I am interested in the best approach for dealing with such loose screws.
My specific questions:
- What methods or tools are especially suitable for tightening screws on BRIMNES furniture?
- Are there any experiences with special screw fasteners or additional reinforcements that Ikea does not directly recommend?
- For this type of furniture, is it generally advisable to just retighten the screws, or are things like PTFE tape, wood glue, or other aids better to fix the problem in the long term?
I look forward to any helpful responses! Thanks in advance.
reogo
klo40
10 Feb 2017 15:18
Hello reogo,
From experience, I can shed some light on how to deal with loose screws in BRIMNES furniture to restore stability.
First, some basics:
- Ikea furniture (including BRIMNES) often uses fasteners like knurled nuts, cam lock fittings, and wood screws, which can become loose through regular use.
- Simply tightening the screws is the first and most important step.
Specific procedure:
- Step 1: Check screws and fasteners and carefully but firmly tighten them using the appropriate tool, usually an Allen key. Be careful not to overtighten, as this can damage the threads.
- Step 2: If the wood around the screw has become too soft and holding power decreases, applying some wood glue into the screw hole and reinserting the screw after a short drying time often helps.
- Step 3: For a more durable repair, using wooden dowels or wood glue combined with small wooden dowels can be effective, although this is somewhat more involved.
- Step 4: In special cases, using medium-strength threadlocker, especially on cam lock fittings, is recommended to prevent the screws from loosening again.
Common mistakes to avoid:
- Over-tightening, which can damage the material.
- Neglecting regular checks.
Summary: Simply tightening is often enough, but with poor wood quality or repeated loosening, combining wood glue and possibly threadlocker is advisable.
I hope this helps you!
Linavin
11 Feb 2017 10:05
klo40 schrieb:
Simply tightening the screws again is the first and most important step.
Interesting point, but I wonder whether "simply tightening" really provides long-term stability, or if it’s just a temporary fix. Especially with furniture like BRIMNES, which has to endure a lot of stress, one could argue that the wood around the screws changes over time – what do you think about that?
klo40 schrieb:
If the wood around the screw has become too soft and the hold weakens, often applying some wood glue into the screw hole and then reinserting the screw after a short drying time helps.
I see clear advantages here, but shouldn’t we first investigate possible causes? For example, fluctuating humidity or irregular loading could constantly weaken the screw hole. Do you think this should be taken into account, or is it really enough to just fix the damage where it occurs?
Regarding screw-locking lacquer or Teflon tape: both can help, but I also have concerns that such measures might either fix the screws too tightly or make replacements more difficult. Does anyone have practical experience that confirms or contradicts this?
In general, I would find it helpful if we knew more about the mechanical properties of the materials IKEA uses – maybe that would make the solutions more meaningful instead of just treating symptoms.
gekira
11 Feb 2017 17:42
The topic of material properties is indeed central. The BRIMNES furniture is mainly made of particleboard with a melamine finish. These materials have significantly less load-bearing capacity around the screw holes compared to solid wood.
Particleboard tends to break or become loose around the screws quickly due to repeated mechanical stress and screw tightening. For this reason, IKEA furniture uses these typical connector fittings that rely on tension and compression rather than purely on screw hold.
In my view, the recommended approach is:
- Tighten screws only semi-firmly to avoid damaging the material
- Retighten screws if they become loose, but avoid damaging the threaded area
- If necessary, reinforce the screw hole by applying a small amount of wood glue into the hole, then adjust by using a slightly smaller or larger screw diameter
Regarding thread-locking lacquer: I see potential drawbacks, as it makes the furniture less service-friendly and can damage the screw threads if overstressed.
My recommendation: Instead of complicated retrofits, regularly check the furniture and, if the particleboard is significantly damaged, repair it using a hammer and some wooden dowels. This method holds much better and is usually reversible.
I hope this summary clarifies the topic and helps you further.
