ᐅ How do you assess the ISOWOOD concept?
Created on: 31 Mar 2023 23:43
Karlsson
Karlsson
31 Mar 2023 23:43
We are currently looking for a general contractor for our building project and came across ISOWOOD Haus. I find the concept very interesting, but I wonder if it truly delivers on its promises. In particular, the fact that they build without a vapor barrier and without controlled residential ventilation – I’m not sure if that can actually work. Maybe you could share your opinions on this, or perhaps you have even built with ISOWOOD and have a few years of living experience with their homes.
WilderSueden
1 Apr 2023 11:27
It will probably work. Wood fiber is not quite as sensitive to moisture and is vapor permeable. However, I still wouldn’t build without ventilation, as fresh air needs to get into the house somehow.
Karlsson
1 Apr 2023 12:55
The wood fiberboard is only on the outside. Inside, there is an OSB board with drywall installed on top. The OSB board essentially acts as a vapor barrier, doesn’t it? Or can moisture also diffuse through it?
WilderSueden
1 Apr 2023 14:05
Yes, OSB acts as a vapor retarder. The key difference compared to other constructions is that the wood fiber insulation between the studs is not susceptible to moisture, whereas mineral wool is.
Karlsson
1 Apr 2023 14:47
Then I still don’t understand what potential moisture in the insulation has to do with the ventilation system. If the OSB board is vapor-retardant, moisture in the insulation would not be removed by the ventilation system. Or am I missing something here?
11ant1 Apr 2023 16:11
Karlsson schrieb:
We are currently looking for a general contractor for our building project and came across ISOWOOD Haus. I find the concept very interesting, but I wonder if it really delivers what it promises. Especially the fact that they build without a vapor barrier and without mechanical ventilation with heat recovery, I can’t really assess if that can work.
That sounds like a general contractor search done without me—unnecessarily in your case 😉 Mechanical ventilation with heat recovery is something you can choose to have or not, but it should never be "replaced" by a wall assembly. If a general contractor told me their magic wall makes mechanical ventilation with heat recovery (assuming you even want one) unnecessary, I would at least keep my distance or even run away. If I were you, I wouldn’t go searching without experienced support (I already pointed you to alternatives).
