ᐅ How can you effectively remove grease stains from Ikea Hemnes furniture?
Created on: 31 Mar 2020 16:37
Eikesin
Eikesin
31 Mar 2020 16:37
I have had a Hemnes sideboard from Ikea in my living room for some time, which unfortunately keeps getting stubborn grease stains. These are often food residues or fingerprints that do not completely come off despite regular cleaning, neither with simple dusting nor with common household cleaners.
My question is: How can Ikea Hemnes furniture be cleaned effectively and gently of grease stains without damaging the painted surface or wood finish? Are there special methods or proven home remedies to reliably remove oil and grease contamination?
I would appreciate any tips on the right cleaning agents, application time, possible pretreatment, or subsequent care. Thanks in advance!
GAGRAHAM
31 Mar 2020 17:08
Hey, what a great thread! 😃 Grease stains on the Hemnes can be really annoying, but don’t worry – they can be removed!
I’ve had good experience with a simple trick: mix some warm water with a small amount of dish soap (use sparingly to avoid too much foam) and gently wipe the spot with a soft microfiber cloth. Don’t use too much water to prevent the wood from swelling! If the stains are more stubborn, I dilute vinegar essence in water – that means 1 part vinegar to 10 parts water – and apply it very gently. Afterwards, be sure to wipe again with a clean damp cloth and then dry the area!
It takes a bit of patience, but I can definitely recommend it. Keep at it, we can do this! 👍
tangi
31 Mar 2020 18:15
Specifically regarding Hemnes furniture: Ikea mostly uses solid pine wood with a lacquer finish for Hemnes, which is easy to maintain but sensitive to harsh cleaners. Therefore, I recommend:
- Avoid strong solvents and abrasive cleaners
- Initially treat affected areas with warm water and mild soap
- For grease stains, a mixture of lukewarm water and a mild, grease-dissolving detergent works well
- After removing stains, polish the surface with a dry cotton cloth to remove moisture
Alternatively, I have had very good experience with a gentle wood care oil that is specially designed for lacquered surfaces. Simply apply it thinly after cleaning; this also restores the lacquer protection. It is important to always test the treatment first in an inconspicuous area.
gasidney
31 Mar 2020 19:02
For grease stains on Hemnes, I use:
- a damp cloth with a few drops of dish soap
- gently wipe, not too wet
- then rub dry
If that doesn’t work, sometimes a little diluted alcohol (e.g., denatured alcohol) on a cloth can help, but be sure to test first.
RETRAVIS
1 Apr 2020 09:14
Eikesin schrieb:
How can Ikea Hemnes furniture be cleaned effectively and gently to remove grease stains without damaging the painted surface or wood finish?
Cleaning grease stains on Ikea Hemnes furniture should always be done gently. Here is my objective, evidence-based recommendation:
- Preferably use pH-neutral or mildly alkaline cleaning agents, such as gentle soap solutions.
- Gently wipe the affected areas with a soft microfiber cloth or cotton cloth.
- Avoid abrasive sponges or aggressive chemicals like gasoline, turpentine, or strong solvents, as these can cause permanent damage to the surface.
- For stubborn grease stains, isopropyl alcohol at a low concentration (around 70%) can be used, but only after testing for compatibility on an inconspicuous spot.
- After cleaning, thoroughly wipe the surface with clean water and carefully dry with a dry cloth to prevent water spots or swelling.
Finally, natural care with furniture wax or specialized wood oils may be helpful, provided they are suitable for painted surfaces, to maintain the protective layer.
This structured approach ensures that the wood grain is preserved and the visual quality of the Hemnes furniture remains protected in the long term.
kogudra
2 Apr 2020 12:45
GAGRAHAM schrieb:
If the stains are more stubborn, I use a little concentrated vinegar diluted in water – that is 1 part vinegar to 10 parts water – apply very gently.
Vinegar can sometimes help, but be careful: on painted surfaces, the acid can damage the paint if it is too concentrated or left on too long. Therefore, I recommend using vinegar only in a very diluted form and spot testing first. It is especially important to thoroughly wipe down with clean water afterwards.
RETRAVIS schrieb:
For heavy grease stains, isopropyl alcohol at a low concentration (around 70%) can be used, but only after a compatibility test in an inconspicuous area.
This is a very important tip. Even better than pure alcohol are special wood cleaners designed to dissolve grease while being gentle on the finish.
The general rule is to start with the mildest method before moving on to stronger treatments.
