ᐅ How do you clean Ikea Pax units with high-gloss fronts?
Created on: 24 Aug 2016 19:37
chenro
chenro
24 Aug 2016 19:37
I have had an Ikea Pax wardrobe with high-gloss fronts at home for several months now. I noticed that while the surface feels very elegant and modern, cleaning it can be somewhat challenging, especially because smudges and dust are easily visible.
My question is: What is the best way to clean Ikea Pax wardrobes with high-gloss fronts without damaging the material, leaving scratches or streaks, and still effectively removing dust, fingerprints, and everyday dirt? I am particularly interested in simple, proven methods or products—recommendations for specific cleaning cloths, cleaners, or household remedies are welcome.
I look forward to your experiences and tips!
Ianlau
24 Aug 2016 20:11
Hello chenro,
This issue often causes uncertainty. Glossy surfaces are sensitive—both to scratches and cleaning products.
First of all: Always use a soft, lint-free microfiber cloth. Dust should be wiped off gently—without applying pressure. For cleaning, a slightly damp cloth with clear, lukewarm water works well. If necessary, a very mild, pH-neutral all-purpose cleaner can be used.
Avoid strong or abrasive agents, as well as harsh chemicals like alcohol or ammonia—they dull the surface or cause unsightly streaks. After cleaning, I recommend gently polishing the surface with a dry microfiber cloth to prevent water spots.
I hope this helps you for now. If you like, we can discuss more detailed tips about cleaners or procedures.
Lance
25 Aug 2016 08:43
Hello chenro,
I can fully understand the challenge, as I myself own a Pax wardrobe with high-gloss fronts and place great importance on cleaning it with as few scratches and streaks as possible. I am happy to go into the details:
1. Preparation:
- Remove dust with a dry, soft microfiber cloth. Use no pressure to prevent scratches.
2. Cleaning:
- Slightly dampen a microfiber cloth with warm water.
- If necessary, add a few drops of gentle dish soap (without bleach or abrasives) to the water.
- Clean the fronts using circular motions.
3. Important:
- Never use scouring agents or abrasive sponges, as high-gloss fronts are sensitive to abrasion.
- Streaks often occur from too much water or the wrong cloth. Therefore, moisten only minimally and always wipe dry afterward with a dry microfiber cloth.
- For stubborn fingerprints, an isopropanol-based solvent can help, but only sparingly and tested first on an inconspicuous spot, as it may damage the coating.
- I recommend using chamois leather after cleaning – it ensures a streak-free shine.
4. Additional tips:
- Remove dust regularly and gently before dirt sets in.
- Avoid spraying cleaning products directly onto the fronts.
Maybe you could also say whether your wardrobe is heavily used or mainly decorative? That could help with more detailed advice.
Ianlau schrieb:
After cleaning, I recommend gently polishing the surface with a dry microfiber cloth to avoid water spots.
I completely agree – when it comes to high-gloss fronts, polishing afterward is essential.
Have you already tried any cleaners? What experiences have you had so far?
chenro
25 Aug 2016 13:29
Thank you for the detailed advice, Lance and Ianlau.
The cabinet is used quite frequently since it is located in the bedroom, and it is often touched by children, so fingerprints and small stains are inevitable. So far, I have tried using microfiber cloths with glass cleaner, but that often leaves streaks and sometimes causes the surface to appear slightly dull.
I have done this sometimes—spraying onto the fronts and then wiping.
So that doesn’t seem ideal.
My main issue is really avoiding unsightly streaks and that slightly matte effect right after cleaning, which clearly reduces the high-gloss appearance.
Are there specific cleaning products that have proven effective?
Which home remedies would you possibly recommend that are not too harsh but still nourishing?
LEOPAU
26 Aug 2016 09:57
Hello chenro,
I’m happy to provide you with a clear step-by-step guide to help with your issue with high-gloss cabinet fronts – this method has worked successfully for me on my own Ikea cabinets:
- Preparation: Always remove dust first using a dry, soft microfiber cloth. Use gentle pressure, as high-gloss surfaces are sensitive.
- Cleaning step: Warm up 1 liter (about 1 quart) of water (not hot), add 1 teaspoon of mild dish soap (look for formulas that are moisturizing and free of harsh additives).
- Dip the cloth into this solution and wring it out well, so it is just slightly damp (not dripping wet!).
- Carefully wipe the fronts in gentle, circular motions.
- IMPORTANT: Immediately follow up by buffing with a dry, clean microfiber cloth to remove any remaining water and streaks.
As a home remedy, I sometimes add a splash of vinegar essence diluted 10:1 in water, which helps against lime spots and streaks if you have very hard water – but you should always test this first on an inconspicuous area.
Regarding cleaning cloths:
- High-quality microfiber cloths specifically designed for delicate surfaces (e.g., cotton-polyester blend) are recommended.
Common mistakes to avoid:
- Spraying cleaning products directly onto the furniture
- Using wet sponges or rags
- Applying too much pressure
If you like, I can also provide a list of products I have personally used that are effective without damaging the surface.
V
van_pe
26 Aug 2016 11:02
I simply use a slightly damp microfiber cloth with a bit of mild dish soap to wipe the fronts, then dry them afterwards. Do not use glass cleaner or harsh chemicals.
Important: Do not use too much water and avoid leaving any foam behind.
