ᐅ How can you clean the Ikea Hemnes furniture in an environmentally friendly way?
Created on: 12 Sep 2020 08:53
Janlis
Janlis
12 Sep 2020 08:53
Good morning everyone, I am looking for environmentally friendly methods to clean the Ikea Hemnes furniture series. It is important to me that the cleaning product used contains no harmful substances and is biodegradable, while still being effective enough to remove dirt such as grease and dust buildup. I am also interested in tips on how to care for the furniture surfaces without damaging the painted or waxed wood finish. So, it’s not just about cleaning, but also about maintaining the durability of the furniture—preferably without harsh chemicals. Does anyone have experience or specific recommendations that are gentle both for the environment and for the furniture? Thanks in advance!
Far34
12 Sep 2020 09:11
It is best to simply use lukewarm water with a little vinegar or lemon juice. Both agents are environmentally friendly and effectively dissolve grease. Afterwards, wipe with a damp cloth to prevent any stickiness.
bente
12 Sep 2020 10:45
I think your question is really important because many of us want to focus on sustainability, but often feel unsure about what cleaning products are safe to use. I once had Hemnes furniture and often cleaned it with a mild soapy water solution — for me, this felt more comfortable since I didn’t have to worry about harsh chemicals. However, I was never entirely sure whether this would affect the surface finish. Does anyone have long-term experience on whether the sealing changes due to this?
elliot
12 Sep 2020 14:23
Environmentally friendly and gentle cleaning of Ikea Hemnes furniture can be achieved using the following methods:
- Use a mild soap solution made from pure soap or vegetable-based soft soap.
- Avoid aggressive solvents or alcohol-based cleaners to prevent damaging the finish.
- A damp microfiber cloth is ideal for picking up dust and gently removing dirt.
- For removing grease, homemade vinegar-based cleaners can be used, but contact time should be brief as stronger acids may damage the finish.
For maintenance, eco-friendly wood oils are suitable if the furniture is waxed or untreated. For painted surfaces, oil-based treatments should be avoided to prevent creating a sticky layer. In general, clean with minimal water to avoid moisture penetrating the wood.
Deandre
12 Sep 2020 17:42
If protecting your furniture is especially important to you, you can divide the cleaning into two steps. First, clean the surface with a damp cloth and a mild, homemade solution (for example, water plus a few drops of organic dish soap). Then, clean again with clear water to remove any residues.
For heavier dirt, I recommend using a non-abrasive sponge – in any case, you should avoid harsh scouring agents, as they can quickly scratch the surface. Personally, I do not use chemical products but rely on home remedies because I am also concerned about indoor air quality.
Janlis
13 Sep 2020 07:32
Thank you for the advice, elliot. You mentioned that vinegar should only remain on the surface briefly due to possible damage to the finish – could you explain this in more detail? I ask because I often hear that vinegar is generally very harsh on finishes. Does this apply only to certain types of finishes or to all Hemnes furniture in general? Also, are there safe alternatives for removing grease that do not contain vinegar or alcohol?
