can someone explain how the knee wall height is correctly calculated?
I currently have quotes from two builders, and they calculate it differently.
Data
Knee wall height 80cm (31.5 inches)
Roof pitch 38°
Wall thickness 36cm (14 inches)
1. 80 cm (31.5 inches) knee wall height on the outside corresponds to about 100 cm (39 inches) on the inside
2. 80 cm (31.5 inches) knee wall height on the outside corresponds to about 65 cm (26 inches) on the inside
Excerpt from the development plan
The knee wall height of the attic must not exceed 80 cm (31.5 inches). The knee wall height is defined as the distance between the top edge of the attic floor and the intersection line of the outer surface of the wall with the underside of the roof covering.
I am not asking for an exact value, but which builder is wrong?!
Chris
Data
Roof pitch 38°
Chris
Chrisbo schrieb:
can someone explain how the knee wall height (kniestock) is correctly calculated?
I currently have offers from two different developers, and both calculate it differently.
Data
Roof pitch 38°
1. 80cm (31.5 inches) knee wall height measured outside corresponds to about 100cm (39 inches) inside
2. 80cm (31.5 inches) knee wall height measured outside corresponds to about 65cm (26 inches) inside
of the attic floor must not exceed 80cm (31.5 inches). The knee wall height is defined as the distance between the upper edge of the attic floor and the intersection line where the exterior surface of the wall meets the lower edge of the roof covering.
I’m not looking for an exact value, but which developer is wrong?
Chris No one necessarily has to be wrong here. It’s more likely about the usable floor area intended. The developer calculating the 65cm (26 inches) knee wall is probably maximizing the interior space and may be using a different wall construction than the one with the 80cm (31.5 inches) measurement.
Bauexperte1 Jul 2016 21:11Chrisbo schrieb:
Can someone explain how the knee wall height is calculated correctly?You can find the calculation method in your regional building code; some municipalities use the intersection with the exterior roof surface as the reference, while others use the intersection with the interior roof surface.Each state or region has its own approach.
Regards, Bauexperte
