ᐅ What is the best way to fill gaps between IKEA Platsa units?
Created on: 23 Aug 2020 08:42
didan
didan
23 Aug 2020 08:42
I am currently planning a larger installation with several IKEA Platsa units, which I want to arrange flush against each other. However, I am noticing that small gaps often appear between the individual modules due to the typical construction and slight dimensional variations of the furniture.
My question is: What methods and materials are best suited for effectively closing these gaps between Platsa cabinets? I am especially interested in solutions that are both visually appealing and stable, as well as durable over the long term.
Does anyone have experience with special trim strips, seals, or possibly suitable filler pieces? Perhaps there are also craftsmanship tips that go beyond the standard measurements to create seamless transitions.
I look forward to detailed advice, including tips on common mistakes to avoid. Thanks in advance!
SUDAN
23 Aug 2020 10:13
Hello didan,
Regarding your question on how to best close gaps between IKEA Platsa units, I’m happy to provide a structured answer based on my experience.
1. Measuring and Alignment: First, it’s important to take precise measurements and align the furniture as accurately as possible. Even small deviations in positioning can lead to unsightly gaps later.
2. Cover Strips or Trim: IKEA offers cover strips designed for some systems to hide gaps. If there aren’t exact fittings for Platsa, you can use universal cover strips made of wood or plastic, which can be cut to size.
3. Flexible Fill Profiles: For narrow and irregular gaps, flexible sealing tapes or foam profiles work well to visually fill the spaces and prevent dust buildup.
4. Craft Tip: I sometimes use small wooden strips in a matching color, fix them with wood glue, and sand any excess for a nearly seamless transition.
5. What to Avoid: People often try to fill gaps with acrylic or silicone sealants. I don’t recommend this for furniture edges, as they offer little durability and tend to look like repairs.
Summary:
- Precise alignment prevents larger gaps
- Use cover strips or trim
- Flexible profiles for irregular gaps
- Wooden strips for custom solutions
If you want more details on any of these points, feel free to ask.
Parbo
24 Aug 2020 07:36
Hello didan,
I would like to give a more detailed perspective on the issue of gaps between IKEA Platsa units, as people often underestimate how challenging it is to achieve a truly seamless connection.
First, be aware that the dimensions of IKEA furniture usually vary by a few millimeters (inches) due to manufacturing tolerances. Even though Platsa modules are theoretically modular, practical deviations can cause gaps.
Specific approach:
- Step 1: Precise planning before assembly. Use a spirit level and align the modules on a flat surface. Even the smallest unevenness at the installation site can increase gaps.
- Step 2: Trial assembly without screws. When connecting the modules, allow some play and check whether connector clips or screws can pull the modules together to minimize gaps.
- Step 3: Material choice for covering gaps. If you still have small gaps, I recommend:
- Thin, self-adhesive wooden strips in a matching wood finish (these can be trimmed to size with a craft knife)
- Flexible foam sealing tape as dust protection
- For larger gaps, possibly cut filler pieces from MDF or plywood and paint them.
- Step 4: Installing covers. Important: Do not use permanent fillers like acrylic, as these do not flex with the furniture material and tend to crack.
- Step 5: Finishing touches. After assembly, you can deburr edges with fine sandpaper and, if needed, retouch the color.
I still have a few questions to help you better:
- How large are the gaps (approximately in millimeters)?
- Are the Platsa units standing on a perfectly level surface, or have you noticed any unevenness?
- What exact color or finish do your units have (this is important for selecting the trims)?
Such precision is crucial if you want clean transitions in the long term.
Regards!
Ethan
25 Aug 2020 14:29
Parbo schrieb:
I have a few more questions to better assist you:
- Are the Platsa furniture pieces placed on a perfectly even surface, or have you noticed any unevenness?
- What exact color or finish do your furniture pieces have (as this is important when choosing molding)?
I find these points very important, so I’d like to add:
In my case, the gaps appeared due to an uneven floor and different thicknesses of the floor panels, which made alignment difficult. That’s why I placed rubber feet under the individual Platsa modules to make leveling easier. After that, the modules fit together better.
Another thing: if color is important, you can sometimes use colored, flexible PVC profiles that can be applied along the edges to visually reduce the gaps. These are also available in white or light gray shades that match the Platsa furniture.
Also, if you are handy, I would recommend stabilizing the joints with wood glue before assembly. This makes the modules very sturdy together and reduces small movements that often cause gaps.
If you need more information, I’m happy to help.
