ᐅ What is the best way to clean Ikea BRIMNES furniture without damaging the surface?
Created on: 7 Sep 2020 19:24
rarichard
rarichard
7 Sep 2020 19:24
I have some Ikea Brimnes furniture at home and want to clean it properly and gently without damaging the surface. The furniture has a white painted finish with a slightly melamine-coated board, which can be sensitive to harsh cleaners or excessive moisture. My question is: What is the best way to clean Ikea BRIMNES furniture to remove dust, fingerprints, and light dirt without causing scratches, dull spots, or other surface damage? Are there specific cleaning products or methods that have proven effective? I want to care for my furniture properly without causing any harm and would appreciate any tips!
JULIANNALO
7 Sep 2020 20:07
It is best to use a soft microfiber cloth and some lukewarm water. For heavier dirt, a mild dish detergent can be used, but only diluted. Important: Do not wipe too wet, as the material cannot tolerate standing moisture. Do not use abrasive cleaners or harsh chemicals.
Lilygla
8 Sep 2020 08:39
The surface of the BRIMNES furniture is indeed made of melamine resin-coated chipboard, which means it has some resistance to moisture but is still sensitive to solvents and mechanical stress. For cleaning, I recommend the following approach: first, remove dust with a dry, soft microfiber cloth to avoid scratches.
To remove fingerprints or light stains, use a slightly dampened microfiber cloth with clear water or at most one drop of mild all-purpose cleaner (e.g., a pH-neutral dish soap). Make sure to wring out the cloth thoroughly so the surface does not get wet, as standing moisture can damage the surface or cause discoloration.
It is very important never to use abrasive cleaners, scouring pads, or alcohol-based/solvent-based cleaners, as these will dull the surface.
A good tip is always to wipe in the direction of the grain or surface pattern and to immediately dry it with a dry cloth after cleaning. For tougher stains, such as dried-on spots, a little soda (sodium carbonate) dissolved in water can help, but only gently with the cloth and only applied locally.
I would be interested to know if you are dealing with larger stains or scratches as well, or if it is mainly about daily maintenance?
sancamille
8 Sep 2020 12:15
Lilygla schrieb:
A good tip is to always wipe along the grain or surface direction and to immediately follow up with a dry cloth after cleaning.
I completely agree. Also, never use wet sponges. Only use a very damp cloth, then wipe dry.
letar
9 Sep 2020 07:48
When cleaning Ikea BRIMNES furniture, please keep the following points in mind:
- Always use mild cleaning agents without harsh chemicals or solvents.
- A damp microfiber cloth is sufficient for regular cleaning.
- Avoid standing moisture, as it can damage the material.
- Remove stains promptly before they dry.
- Do not use abrasive sponges or pads, as they can destroy the protective layer.
Additionally, I recommend occasionally refreshing the furniture with a slightly damp, clean cloth to remove everyday residues from the surface. When in doubt, test on an inconspicuous area first.
Donar34
10 Sep 2020 10:36
In addition to the previous tips, I would like to point out that Ikea BRIMNES is mainly made of melamine-coated particleboard, which is durable but sensitive to moisture and mechanical stress. For this reason, you should:
- Avoid using aggressive cleaners (no alcohol-, ammonia-, or solvent-based products).
- Use only a microfiber cloth that prevents fiber abrasion.
- Immediately remove any excess water to prevent water stains and swelling.
Regular gentle wiping is usually sufficient to remove dust and light dirt. For stubborn stains, I recommend a mixture of lukewarm water with a drop of mild detergent. This method is proven and prevents surface damage.
It is advisable not to clean frequently with aggressive agents, as this can cause micro-cracks in the protective layer over time.
