ᐅ What is the best way to secure Ikea Pax wardrobes to concrete walls?
Created on: 20 Apr 2024 08:46
mubuka
mubuka
20 Apr 2024 08:46
Hello everyone, I am planning to mount my Ikea Pax wardrobe system on a concrete wall soon and am looking for the best approach to do so. I am particularly interested in which types of anchors and screws are most suitable for a stable and secure attachment of the wardrobe units to solid concrete walls, without damaging the wall or the wardrobe. Does anyone have experience with specific fastening methods, such as chemical anchors or specialized heavy-duty anchors? It would also be helpful to get practical advice on how to pre-drill the holes, including which drill bit to use and the appropriate drilling depth to ensure optimal stability. Thanks in advance for your tips!
ju_ren
20 Apr 2024 09:12
For concrete walls, I recommend heavy-duty anchors or chemical anchors. Drill with a hammer drill and SDS-plus bit. The drilling depth should be at least 10 mm (0.4 inches) longer than the anchor length to ensure the anchor fits completely.
Maria35
20 Apr 2024 09:47
Regarding the attachment of Ikea Pax wardrobes to concrete walls, the following applies: The basis should be high-quality heavy-duty anchors, preferably metal, with a diameter of at least 8 mm (0.3 inches). Pre-drilling should be done using a suitable SDS drill bit that matches the anchor diameter exactly. It is important to clean the drilled hole thoroughly afterward (using compressed air and a brush) to ensure optimal anchorage of the anchor. Chemical anchors offer higher load capacity but are generally not necessary for standard Ikea wardrobes, except in cases of above-average load or unusual wall conditions.
Palenar
20 Apr 2024 10:34
For attaching Ikea Pax wardrobes to concrete walls, I recommend the following multi-step procedure: - First, thoroughly inspect the wall for any cracks or loose areas, as this will affect the choice of anchor. - For drilling holes, I suggest using an SDS-plus rotary hammer with a drill bit that matches the anchor size—usually 8 or 10 mm (around 0.3 or 0.4 inches) works well. - The drilling depth should not only cover the length of the anchor but be about 1 to 2 cm (0.4 to 0.8 inches) deeper to avoid accumulation of drill dust strands. - Then, make sure to clean the holes carefully with compressed air or a vacuum cleaner. - For anchors: metal expansion anchors provide high load capacity and are reliable for heavy furniture. Alternatively, chemical heavy-duty anchors are ideal, especially if the wall surface is irregular or porous—here, the resin seals the pores and significantly improves holding strength. - Screws should be galvanized or stainless steel, with a minimum length of 60 mm (2.4 inches). - Finally, ensure the wardrobes are fixed to the wall at at least three points to prevent tipping. One more thing: if you plan to use chemical anchors, please specify the exact wall condition. This is important to recommend the appropriate resin product. Is the wall very smooth, porous, or rather sandy?
mubuka
20 Apr 2024 11:02
Palenar schrieb:
If you want to work with chemical anchors, I would ask you to specify the exact wall composition. This is important in order to provide a suitable recommendation for the resin product. How is the wall—very smooth, porous, or rather sandy?
Thank you for the detailed post; I had struggled with this exact question as well. The wall is actually quite smooth and solid; it is made of solid concrete with a fairly smooth surface. It’s not an old plastered wall or anything like that, more like standard new-build concrete. Am I correct in assuming that for such a wall, standard heavy-duty anchors should be fully sufficient?
kieran
20 Apr 2024 11:46
mubuka schrieb:
Am I correct in assuming that standard heavy-duty anchors should be completely sufficient for such a wall?
Yes, that’s correct. For smooth, solid concrete walls, metal expansion anchors or high-quality heavy-duty anchors are ideal. It is important to clean the drill hole thoroughly and use the correct drill depth to ensure the anchor is fully tensioned. Chemical anchors are typically reserved for cracked or porous walls, where they provide better grip. In your case, heavy-duty anchors combined with an SDS drill bit are the best, most practical, and cost-effective solution.
