ᐅ How can Ikea BRIMNES furniture be secured to the wall without drilling?
Created on: 6 May 2023 08:47
iainpau
iainpau
6 May 2023 08:47
Hello everyone, I’m looking for your experience and ideas on securing Ikea Brimnes furniture, specifically methods that don’t require drilling into the wall.
I want to find ways to safely fix these pieces without damaging the walls, for example in rental apartments where drilling holes is often not allowed. The furniture is quite heavy and shouldn’t just stand unstably or easily tip over.
Does anyone know alternative securing methods, such as special adhesive products, clamping devices, or other solutions that provide enough stability? It’s also important to me to know which wall types these methods work on and, of course, their load-bearing capacity.
I look forward to any tips, personal experiences, and also advice regarding potential safety concerns.
lubla
6 May 2023 09:14
Hi, you can use special adhesive pads or mounting adhesive.
However, I consider this risky for heavy furniture like BRIMNES.
Alternatively, door wedges work well if you want to secure furniture in a niche or between other pieces of furniture.
Ramon4
6 May 2023 10:58
Hello iainpau, from experience I can say that attaching furniture like BRIMNES without drilling is quite challenging, especially due to stability requirements and weight.
A practical solution is to use special adhesive anchors or high-strength mounting tape that sticks well to smooth, clean surfaces. However, make sure the wall surface is completely grease-free and smooth. This works best on smooth wallpaper or finished drywall panels.
Another option is to use non-slip mats or rubber pads under the furniture, combined with a bracing system (such as tension rods that extend from floor to ceiling) to secure the furniture against tipping.
Note: None of these methods provide the same safety as a properly anchored wall fixture. Extra caution is advised, especially around children or pets.
Danial
6 May 2023 12:22
Ramon4 schrieb:
A practical solution is special adhesive anchors or mounting tape with high load capacity, which adhere well to smooth, clean surfaces.
The question is whether these adhesive products are truly reliable in the long term given the weight and height of BRIMNES.
Without detailed load tests or manufacturer information, I would consider this insufficiently stable. Especially in rental apartments, there is often an insistence on "no drilling," but a safety measure that only holds under test conditions can pose a hazard.
I often find the explanation lacking on how these methods actually keep the furniture stable in everyday use over months. Who takes liability in the event of damage?
U
usbla
7 May 2023 07:38
To secure Ikea BRIMNES furniture without drilling, the structural strength of the wall and the fixing materials used is crucial.
Adhesive anchors or double-sided mounting tapes can generally work if the wall surface is completely clean, dry, and smooth. However, this method is only reliable for light loads.
For heavy or tall furniture like BRIMNES, experts recommend stabilizing measures such as tension systems between floor and ceiling or between pieces of furniture.
Only this physical fixation ensures that the furniture will not tip over under pulling or impact forces.
It is essential to check the load capacity of these aids on the specific wall surface in advance and to follow the manufacturer’s instructions for the adhesive products.
In summary: full load safety without drilling is hardly achievable. Alternatively, removable plug-in fasteners can often be used instead of drilling.
te-min
7 May 2023 15:47
I recommend not only securing furniture at the front but also improving its base support.
Underlays or special anti-slip rubber mats can effectively prevent tipping.
Clamping systems that connect the floor and ceiling provide strong support without the need for drilling.
