ᐅ How do you securely mount BILLY shelves in older buildings with crumbling walls?
Created on: 8 Dec 2018 08:03
dratan
Hello everyone, I have the following problem: I want to install my Billy shelves in an older apartment where the walls are quite crumbly, with some plaster even falling off. The usual wall anchors don’t seem to provide enough support here. My question is: which method, technique, or material would you recommend to securely and permanently fix these shelves to such fragile walls? Are there special anchors, maybe some kind of reinforcement, or alternative mounting options that are practical for older buildings with these wall conditions? I look forward to any tips, especially if you have practical experience. Thank you!
batabe schrieb:
Old walls often have unstable plaster, so use a wooden batten as a substructure. That sounds interesting, could you explain the substructure in a bit more detail? Would that mean I first screw a batten to the more stable parts of the wall and then attach the shelf to it, instead of drilling directly into the wall? And how do you fix such a batten if the wall itself is already crumbling? Thanks!
dratan schrieb:
Does this mean I first screw a batten into the more stable areas of the wall and then attach the shelf to it? That's exactly what I mean. When you can't get a secure anchor in very crumbly spots, you look for suitable load-bearing areas (e.g., directly into the masonry or sections with firmer plaster). There, you attach a smooth, preferably sturdy wooden batten (for example, a planed roof batten) using strong anchors or chemical fixings. You then mount your Billy shelf onto this batten. This way, you distribute the load across multiple fixing points and avoid putting direct stress on unstable plaster surfaces.
dratan schrieb:
And how do you fix such a batten if the wall itself is already crumbling? At the spot where you want to fix the batten, carefully check whether you can reach load-bearing masonry with a small drill. Usually, there is solid masonry beneath the plaster. Use chemical anchors there. If the entire wall is crumbly, you should consider whether a freestanding shelving solution (a shelf without wall mounting) might be a better option.
batabe schrieb:
Screw a metal or wooden batten onto a stable wall and attach the shelf to it. I quite like the retro industrial vibe this gives off 😉 Who would have thought that roof battens would become a design element? But seriously, the idea works. Always think about distributing loads evenly and better to screw in over a wide area rather than at single points.
Thanks for the previous tips, the idea of a substructure sounds reasonable. What about the use of so-called "hollow wall anchors" or "expansion anchors" for crumbling walls? I have read that they are sometimes used on weaker substrates. Or are they rather unsuitable for old building crumbling plaster?
