Nar_nar624 May 2024 08:37Hello everyone,
I recently assembled a piece of furniture from the Ikea Brimnes series and started wondering about the hinges. My question is: How exactly do the hinges work on Ikea BRIMNES furniture, especially on the doors?
I’m interested in what type of hinge is used, how they are constructed technically, whether they are concealed or surface-mounted hinges, and how the doors operate in everyday use – for example, whether they close softly with damping, how they can be adjusted, and if there are any special considerations during installation.
If anyone has experience with these hinges or can provide information about the mechanism, I would greatly appreciate a detailed explanation.
Best regards!
Best regards!
Hello Nar_nar62,
your question about the hinges of the Ikea BRIMNES furniture is very well asked, and I’m happy to help. The doors of BRIMNES usually use concealed cup hinges (also known as concealed or European hinges). These hinges are mounted inside the furniture and are not visible from the outside, providing a clean design.
Technically, these hinges consist of two main parts: a cup that is recessed into a borehole in the door, and a mounting plate that is attached to the side panel of the furniture. The connection of these two parts allows the door to pivot.
The hinges often come with integrated soft-close dampers, ensuring the doors close quietly and smoothly. Additionally, they offer adjustment in three directions, so you can fine-tune the door to reduce gaps or improve alignment.
During installation, be sure that all screws are tightened securely and that the damping mechanism functions properly. The hinges are attached to the carcass with pre-drilled holes – Ikea usually provides the appropriate screws and instructions.
I hope this gives you a good overview. If you have any specific questions about adjustment or common issues, just let me know.
Nathanaelk5 May 2024 13:26Hello Nar_nar62,
to answer your question in more detail, I would like to explain the structure and functioning of the hinges on the Ikea BRIMNES in a more technical way, as I assume you also want to know what to pay attention to during assembly and adjustment:
- The hinges are so-called concealed cup hinges with a soft-close damping mechanism. This means there is a small hydraulic damper inside the hinge that slows down the door when closing to prevent loud slamming.
- The cup part has a diameter of approximately 35 mm (1.4 inches) and fits into a precisely drilled hole in the door, which Ikea supplies pre-made. The hole also serves to position mounting clips.
- The mounting plate is attached to the side panel of the cabinet. Between the cup and the mounting plate, there is a joint that enables the swinging motion.
- For adjustment, there are screws:
- One screw adjusts the load and closing force of the damper.
- A second screw allows horizontal shifting of the door to align gaps.
- A third screw permits height adjustment for more flexibility.
- During assembly, be careful not to tighten the screws too much, as this can compress the damper excessively and make the door harder to close.
- It is also important to regularly check whether the hinges are still properly adjusted, since material variations or slight distortions in the furniture can sometimes cause misalignment.
If you have trouble with the hinge snapping into place, this can be due to a small plastic part that activates the damper – sometimes this requires attention during assembly to ensure nothing is stuck.
If you like, I can also give you tips on how to solve common daily problems with hinges.
Nathanaelk schrieb:
The hinges are so-called concealed cup hinges with a soft-close damping mechanism.That sums it up well. An important technical addition:
The hinges on Ikea BRIMNES furniture usually feature a groove/elongated hole attachment on the mounting plate, which simplifies adjustment and ensures that the doors can be aligned with millimeter precision after installation. This is especially important for mass-produced furniture, as it helps to compensate for manufacturing tolerances.
It should also be noted that the soft-close function includes an integrated hydraulic damper that is activated by the speed at which the door is closed. This means that faster closing results in stronger damping compared to slower movements.
If there are issues with the hinge operation, cleaning the joint and checking the lubrication may be helpful. Ikea typically uses maintenance-free plastic or metal components here, but they can still be affected by heavy use or dirt buildup.
Overall, the system is designed to be durable and low-maintenance, which is an important factor for value-for-money furniture.
Nar_nar62 schrieb:
whether there are any special considerations during installationRegarding this point, I wanted to add: When installing the hinges, you should be very careful to use the pre-drilled holes precisely, as otherwise the damping function can be affected. Also, the screws should not be too loose – even slight play can cause squeaking doors or make them hard to open.
The adjustment screws are designed for solid assembly but should not be tightened too much, especially the depth adjustments, since overtightening can limit the hinge’s function.
I once had an issue where the mounting height of a cabinet was slightly off, and by readjusting the vertical screw, the problem was quickly resolved without having to replace the hinge.
If desired, I can also share tips on regular care and maintenance. The hinges require little maintenance but benefit from occasional checks.
