ᐅ How do other users repair their Ikea PLATSA shelves?
Created on: 12 May 2024 08:37
chenbau32
Hello community, I have a question for everyone with more experience using Ikea PLATSA shelving: How do other users repair or reinforce their PLATSA units when individual modules or connection points become weak or damaged? I am especially interested in sustainable or practical solutions you apply to improve the stability and durability of the structure without replacing entire modules. Are there any specific tips for strengthening the joints, dealing with bent metal parts, or defects in the mounting plates? Also, any advice on suitable accessories or custom DIY additions that are compatible with the PLATSA system would be very helpful. Thanks in advance!
GiRoyce
13 May 2024 08:42
Regarding back panels: These are indeed a crucial factor for the stability of Platsa shelves. If the back panels are damaged or not properly fitted, I recommend the following steps:
- First, remove the entire back panel
- Check whether the edges of the back panel are intact or if parts are frayed or broken
- If the back panel is only slightly warped, it can be carefully straightened by pressing it flat on an even surface and, if necessary, weighting it down with heavy objects while it dries
- For attachment, I suggest installing small angle brackets (e.g., aluminum angles) on the inside corners to provide additional support
- Alternatively, the back panel can be secured with small screws if the material allows it (drill carefully)
If a back panel is beyond repair, the most cost-effective solution is to have a wood fiberboard (MDF or HDF) cut to size and attach it using fabric glue or double-sided tape. Although this does not look exactly like the original, it fully serves the stability function.
Marcellela
13 May 2024 09:14
For damaged fasteners, simply replacing the clips often helps. These are sold individually at Ikea and can be easily swapped out.
Otherwise, I recommend using angle brackets to securely connect the modules. This provides a reliable hold even under light loads.
If the back panels are damaged, they can be replaced with suitable MDF boards. Make sure to fasten them securely.
