ᐅ How can I use IKEA Besta units most effectively in corners and recesses of my home?
Created on: 13 Apr 2021 08:32
O
Onirakli
O
Onirakli
13 Apr 2021 08:32
Hello everyone, I have a specific question regarding IKEA Besta and the optimal use of corners and recesses in my home. I am particularly interested in how to arrange the flexible Besta units to provide maximum storage space without wasting corner areas or making them impractical. Are there proven assembly methods or combinations that work especially well for challenging room shapes? Additionally, I would like to know if extra measures, such as special accessories or custom modifications, are useful to make the most efficient use of corner spaces. I look forward to your input, tips, experiences, and general advice to avoid mistakes during my planning.
pauPierce
13 Apr 2021 09:11
This is a very practical question that involves several aspects. IKEA Besta systems are fundamentally modular, allowing you to adapt precisely to the conditions on site. However, there are some points to consider if you want to make the most of corners and niches. First, it would be helpful to know the exact measurements of your corners or niches since Besta components are made in standard widths (e.g., 60 cm (24 inches), 40 cm (16 inches)). For example, if you have a room corner that is less than 120 cm (47 inches) wide, you either need to work with smaller modules or accept some space loss due to cutouts.
In the process, I recommend the following approach:
- Accurate measurement of the niche including height, width, depth, and any sloping ceilings.
- Selection of suitable Besta components that best match the available space. Tall cabinets, wall cabinets, and sideboards can be combined flexibly.
- If gaps remain in the corners, many adjustments can be made using panels or small shelves for customization.
IKEA accessories such as decorative panels or edge profiles are also useful for visually smoothing out these modifications.
I’m wondering: How long are the niches, and are there any special features like radiators or window sills that need to be taken into account?
bente
13 Apr 2021 09:45
I like that you asked the question in such detail because dealing with corners and alcoves is really not always easy. I have a corner in my living room myself that was never used optimally until I switched to Besta. What helped me was not just taking the measurements rigidly but also looking at the corner from different perspectives. It also helps to think in advance about what you want to store there. For example, I converted a corner into a small media shelf that also provides storage space for DVDs and equipment. What I learned from this is that flexibility during assembly is worth its weight in gold, so it’s better to assemble it first without fixed screws and try out how the modules fit together. Often, it’s the small adjustments that make all the difference in the end. Don’t be discouraged if everything doesn’t run smoothly right away!
gadalu
13 Apr 2021 10:22
Here is a structured summary: - The Besta series is designed for modular use; standard depths are usually 40 or 60 cm (16 or 24 inches), which is crucial for efficient space use in corners. - Low sideboards or cabinets with a depth of 40 cm (16 inches) are particularly suitable for corners to save space, especially where walls meet. - In niches, using units with adjustable heights is recommended depending on the ceiling height. In some cases, half-height units can be used to make surfaces more functional. - Accessories such as cover panels, trims, and especially furniture backs help create clean finishes and improve the overall appearance. - For very tight or irregular spaces, adjustments can be made by individually shortening side panels and back panels. - Important: Use the Besta configurator tool from IKEA to test module combinations and also check the load capacity of individual shelves when using them as storage in niches. I recommend verifying the maximum load specifications in the product descriptions. Important for the original poster: Are there any obstacles in your niches, such as radiators or power strips, that need to be taken into account?
O
Onirakli
13 Apr 2021 11:03
Thanks in advance for your detailed comments! The niches vary quite a bit, but they are mostly about 80 cm (31.5 inches) wide and 45 cm (17.7 inches) deep. Regarding depth, I think I’m fine with Besta if I choose a depth of 40 cm (15.7 inches), right? Radiators are sometimes on the walls, but there is enough clearance. What I’m especially interested in is how you handle the room corners where two Besta units meet at a 90-degree angle, and whether there are special connectors or mounting options that ensure a solid hold without wasting space. I’m a bit concerned that otherwise it might feel unstable or gaps could appear.
pauPierce
13 Apr 2021 11:45
Onirakli schrieb:
What interests me most is how you handle room corners, specifically when two Besta units meet at a 90-degree angle, and whether there are special connectors or mounting options for that
The connection method at a 90-degree angle is a key aspect, especially to ensure stability. IKEA does not provide any special corner connectors for Besta units by default. Therefore, I usually use the following approach:
- Use angled wooden connectors or metal brackets that can be discreetly mounted from the outside (or possibly inside if the doors close flush).
- Add extra sturdy screws into the side panels, ideally pre-drilled, to firmly join the modules.
- Clamps are helpful during assembly to keep the angle precisely at 90 degrees.
- If needed, a small internal frame made of wooden strips can reinforce the corner connection from the inside without creating visible side joints.
So, more of a DIY solution is required since IKEA does not supply corner connectors. Also, be careful not to install visible mounting brackets on the outside if a uniform appearance is important to you.
