ᐅ How can I best use Ikea BESTA as a dresser in the bedroom?
Created on: 18 Sep 2024 17:13
Waldtraud6
Waldtraud6
18 Sep 2024 17:13
I am interested in how to use the Ikea Besta system as a dresser in the bedroom in the most effective way possible. Specifically, I want to create enough storage space for clothes and personal items while also making the appearance as cozy and well-suited to the bedroom atmosphere as possible. It is especially important to me to have a good layout of the drawers or doors so that everything remains organized and frequently used items are easily accessible. How have you arranged the BESTA system in your bedroom? Are there any clever installation or modification ideas that make the furniture particularly functional? I would also be very interested in tips regarding materials, colors, or additional accessories. Thank you in advance for your experiences and suggestions!
RENMA
18 Sep 2024 18:27
The BESTA system is originally designed as TV furniture but can be adapted relatively easily as a dresser for the bedroom. The first important step is to choose the right basic structure: a frame with drawers is much more practical for clothing than just doors, as drawers provide better access and help keep things organized. I recommend combining different drawer heights, for example, larger ones at the bottom for sweaters and jeans, and smaller ones at the top for underwear and accessories. Optionally, you can improve the interior organization with inserts or small boxes to maintain order.
Regarding the appearance, it makes sense to coordinate the fronts with the bedroom’s color scheme – both matte and high-gloss finishes on both sides are possible, depending on the existing style. Additionally, it is a good idea to avoid placing the dresser directly on the floor; adding legs underneath will give it a lighter and more homely feel.
In summary:
- Choose a frame with enough drawers
- Combine various drawer heights
- Improve interior layout with inserts
- Select front colors to match the room
- Add legs or a plinth for a better look
This way, you can create a very functional and visually appealing dresser with BESTA in the bedroom.
Filippo
19 Sep 2024 09:42
RENMA schrieb:
I recommend combining different drawer heights, for example, larger ones at the bottom for sweaters and jeans, smaller ones at the top for underwear and accessories.
This is a very important point. I’d like to add my experience: when converting the BESTA system into a wardrobe, I completely restructured it by integrating subtle interior lighting. This way, I can see the contents better, especially with drawers that have dark fronts.
Furthermore, it’s advisable to use drawer organizers made of plastic or bamboo to keep clothing neatly separated and avoid wrinkles. A small tip is to line the drawers with self-adhesive anti-slip mats – this prevents stored items from sliding around.
Another aspect to consider is width: if space allows, placing two BESTA units side by side, possibly with a working or decorative surface on top, is a good way to optimize both storage and surface areas.
Could you please specify the size of your bedroom and how much space you have planned for the dresser? That would help provide more precise advice.
Waldtraud6
19 Sep 2024 12:56
Filippo schrieb:
Could you clarify the size of your bedroom and how much space you have planned for the dresser?
Sure: My bedroom is about 15m² (160 sq ft) with a rectangular layout. I want to place the BESTA dresser against one wall, with a maximum width of 1.80m (5 ft 11 in) and a depth of 60cm (24 in), due to limited space between the door and window. There are no special built-ins, but the power outlets are on the side, so I would prefer a certain height to accommodate cables for charging stations, etc., on the dresser.
The idea of internal lighting and non-slip mats sounds very good. I also value easy cleaning, as I like to avoid dust on smooth surfaces.
I am also interested in how the assembly of different legs affects stability. Are the standard IKEA legs sufficient for this, or would it be better to buy more sturdy alternatives?
Lorukeo
19 Sep 2024 15:37
Waldtraud6 schrieb:
I’m also interested in how the installation of different feet affects stability.
The original IKEA feet for BESTA are sufficiently stable as long as the furniture is not overloaded. The large, height-adjustable feet are recommended, as they can also compensate for uneven floors.
For use as a dresser, feet with a height of 10–15 cm (4–6 inches) are suitable, since they provide a comfortable working height and make it easier to clean dust underneath.
If you want additional storage inside, you might consider adding a bottom drawer with an insert drawer (e.g., from third-party suppliers) to use the space efficiently, provided stability is maintained.
My tip: Make sure all parts are securely screwed together and, if necessary, secure the units to the wall to prevent tipping.
lyndon
20 Sep 2024 08:15
I would like to point out that when using BESTA as a dresser in the bedroom, the choice of handles has a significant impact on usability. Flat, simple handles look more elegant and do not get in the way when leaning on the dresser or cleaning it.
Furthermore, IKEA’s standard drawer slides and runners are generally sturdy, but I recommend checking the tracks upon delivery and lubricating them if necessary to ensure smooth drawer operation. This is especially important for frequent use in the bedroom.
Regarding appearance: matte-finished fronts show fewer fingerprints compared to glossy ones. For longer service life, the fronts can also be replaced, keeping the system flexible.
