ᐅ How can I make the most efficient use of IKEA BESTA furniture in my hobby room?
Created on: 28 May 2023 19:37
Sonjan
Sonjan
28 May 2023 19:37
I would like to start an in-depth discussion on the topic: How can I use IKEA Besta furniture as efficiently as possible in a hobby room? My situation is that I have a moderately sized hobby room, which I want to design to be as multifunctional and space-saving as possible. I like the BESTA series because of its modular construction, the variety of cabinet sizes, and the flexibility with doors, drawers, and shelves. My question is: What strategies do you know for optimally combining and using BESTA furniture in a hobby room? How can items like tools, materials, small machines, and even some bulky hobby equipment be stored in a space-saving and functional way? Are there proven layouts, clever uses of inserts (boxes, dividers, inserts), or perhaps unusual ideas for repurposing the furniture? I would be very interested in practical tips, must-have inserts, and experiences with the adaptability of the BESTA series, especially for creative or technical hobby rooms.
NOAHSAU
29 May 2023 07:42
Sonjan schrieb:
What strategies do you know to optimally combine and use BESTA furniture in the hobby room?
I find the whole idea of being "maximally efficient" with IKEA furniture a bit overrated. Sure, BESTA is versatile, but if you really want optimal space utilization, custom-made solutions are usually better. Still, if you insist on BESTA, I recommend stacking modules easily – the higher, the more storage space, but keep in mind: accessible storage is more important than simply having a lot of storage.
Sonjan schrieb:
How can items like tools, materials, smaller machines, and some bulky hobby equipment be stored space-efficiently and functionally?
Many make the mistake of putting everything into open compartments. It’s better to use closed cabinets so it doesn’t look messy. For bulky items, go for wide, shallow drawers. Also, don’t forget that the shelves often can’t be adjusted precisely—usually only roughly—so measure carefully before buying. Last but not least: BESTA doors aren’t super sturdy, so if you store sharp or heavy tools inside, the doors might get damaged.
In principle, the BESTA series is more designed for living rooms or moderate storage needs, but with enough bins and boxes, you can make it work. However, in a hobby room with a lot of tools and parts, it’s more of a compromise.
Jensson
30 May 2023 14:19
Here is a structured suggestion on how to make the most efficient use of IKEA BESTÅ furniture in a hobby room:
- Take measurements: First, measure the room precisely – width, height, depth, and consider important limitations such as windows, doors, and radiators.
- Module selection: BESTÅ offers various widths (60cm (24 inches), 120cm (47 inches)), heights (38cm (15 inches), 64cm (25 inches), 128cm (50 inches)), and depths (40cm (16 inches), 20cm (8 inches)). For hobby rooms, the deeper 40cm (16 inches) modules are often practical, while the shallower 20cm (8 inches) option fits narrower spaces.
- Organize the interior smartly: Use dividers, drawer inserts, and boxes to sort tools or accessories by category. This helps avoid “clutter in open shelves.”
- Surfaces: Use the top panels to create small workspaces or areas for smaller devices (e.g., rotary tool, soldering iron).
- Doors vs. open compartments: For a workshop atmosphere, I recommend closed doors to keep dust out. For better visible storage, transparent boxes behind glass doors are an option.
- Combine with wall hooks: BESTÅ can be supplemented with wall hooks or magnetic strips on adjacent walls to keep, for example, screwdrivers within easy reach.
- Flexibility: Place the cabinets on plinths or castors if the room is sometimes used for other purposes (e.g., an additional painting or crafting table).
Good planning before furnishing is essential. Don’t just place the modules randomly; think from the start about which items will be stored and how often you need access.
If you like, I can also create a sketch showing how I would arrange something like this.
Genevieve
31 May 2023 20:53
NOAHSAU schrieb:
I find the whole idea of "maximum efficiency" with IKEA furniture somewhat overrated.
I find this skepticism interesting; however, I believe there is too much distinction made between "maximum efficiency" and "custom-made" without giving enough credit to the potential of modular furniture. In particular, BESTA scores well with its modularity and adaptability, which can also serve technical or creative hobby spaces effectively.
Jensson schrieb:
I recommend closed doors for a workshop atmosphere to keep dust out.
I agree, but with an additional comment: closed doors do protect against dust but also limit visibility of stored items. Especially if you work with frequently changing materials, a mix of glass doors and open shelves would be practical for quick overview while still offering protection.
My tip for hobby room users with BESTA is to upgrade the furniture with well-thought-out inserts (boxes, divider systems, stacking options) and to definitely take advantage of the modular features. This way, vertical and horizontal layers can be created inside the cabinets, providing a lot of extra storage space and helping to maintain order.
Furthermore, I would question critical points such as the load capacity of the top panels and the stability of the door hinges—do other users know if this furniture can be reliably loaded with heavy tools over time without risk of damage? Such an assessment is crucial for efficiency and is often underestimated.
