ᐅ How can I use IKEA BESTA as a room divider that is both practical and visually appealing?
Created on: 3 Jan 2020 08:17
BUMAPRA
BUMAPRA
3 Jan 2020 08:17
I plan to reorganize my living room and use IKEA Besta as a room divider. My main question is: How can I practically use IKEA Besta as a room divider to visually structure the space in an appealing way without losing functionality and storage capacity? I’m especially interested in which combinations of elements and materials work well and how to achieve a harmonious look. Are there any recommendations regarding color schemes and layout? Tips on stability and assembly would also be greatly appreciated. Looking forward to your experiences and ideas!
mesila
3 Jan 2020 10:42
Hello BUMAPRA,
I can gladly recommend a structured approach for using IKEA BESTA as a room divider.
1. Dimension planning: First, determine the desired divider height and width. BESTA units come in various heights; choose one that doesn’t completely close off the space to maintain light flow.
2. Combining open and closed compartments: To make the room divider both practical and attractive, use a mix of open shelves (for decorative items) and closed cabinets (for storage).
3. Color design: White is classic and brightens the room, but you can also add accents with black or wood-colored frames.
4. Stability: It’s best to connect the units together and secure them to the wall if the room divider remains freestanding.
5. Accessories: Use drawer fronts or cabinet doors with different colors or glass inserts for a visually appealing effect.
Avoid common mistakes like an overly deep unit that can visually overwhelm the room.
If you like, I can also sketch a sample configuration for you.
blapau
3 Jan 2020 13:26
I would like to add that most users highly recommend the BESTA series when combined with lighting elements. LED strips on the shelves or behind open compartments not only highlight the contents but also create a welcoming atmosphere in the room.
When assembling, make sure the room divider is stable, especially if it is frequently used as a partition. A secure setup also prevents it from tipping over, which is particularly important if there are children or pets.
Additionally, it is advisable to finish the back panels of the furniture with a uniform material or color to achieve a calm visual effect.
fugolo
4 Jan 2020 07:53
Good morning,
building on the previous posts, I would like to provide a brief guide on how to use the BESTA modules as a multifunctional room divider:
- Step 1: Space Analysis
Take a close look at the area you want to separate and consider the purpose the room divider should serve (e.g., storage, privacy screen, display).
- Step 2: Selecting the Modules
For example, a mix of tall and low units can create interesting room heights while still providing enough storage space.
- Step 3: Combining Materials
Nowadays, there are many options for doors, fronts, and shelves, including glass or wood finishes. This expands your design possibilities.
- Step 4: Functional Integration
I recommend using soft-close hinges for smooth closing and adding feet or a plinth to keep the room divider off the floor, making cleaning easier.
In conclusion: Avoid overly tall or cluttered arrangements; this keeps the space airy and maintains an open feel.
bente
4 Jan 2020 12:38
I really like how you have already gathered so many practical tips! Personally, I also struggled with some doubts because I was worried that the room division might feel too "heavy."
What helped me was displaying some personal items and plants openly to make the partition wall feel more lively.
Additionally, I used soft rugs and matching curtains to visually soften and separate the two areas better.
Maybe also worth noting: pay attention to natural light. Sometimes the room division is positioned in a way that makes the space darker. In those cases, a smart combination of open shelves and glass fronts can be very helpful.
sanjon
5 Jan 2020 09:15
If you want more storage space, it’s best to choose the larger BESTA units with drawers. Drawers are more practical than doors if you need frequent access to the contents.
For the room divider, I recommend a height of 120-150 cm (47-59 inches) so that the space remains open but still provides a clear separation.
