ᐅ How can I use IKEA BESTA most effectively for home office storage?
Created on: 13 Sep 2024 08:43
soismailGood morning everyone, I’m currently considering how to set up my home office storage using IKEA Besta in the most efficient way. This furniture series offers various options with adjustable shelves, doors, drawers, and different sizes. My specific question is: How can I use the BESTA units in a home office so that I have quick access to work materials, while also neatly storing documents and electronic devices? Are there any particular organizational approaches that have proven effective, such as certain combinations of drawer inserts or storage boxes that fit well in the BESTA modules? Additionally, I’m interested in how to integrate cable management effectively, since I have several charging cables and peripheral devices. I’m looking forward to your experiences and tips that go beyond the obvious.
Hello, to use the IKEA BESTA optimally in a home office, it is important to have a sensible combination of open and closed storage areas. Open compartments allow quick access to frequently used items such as notebooks, while closed cabinets and drawers provide secure storage for documents and electronic devices. Drawer inserts are useful for organizing cables, pens, or smaller office supplies to avoid clutter. Modular storage boxes that fit precisely inside the internal dimensions of the BESTA units, either from IKEA or third-party suppliers, are also recommended. For cable management, special cable grommets can be integrated into the back panels, and cable channels can be installed under the work surface. This visibly reduces cable clutter and improves functionality. It is advantageous not to consider the BESTA in isolation but to plan it as part of a comprehensive workspace concept with clear states for "in use" and "put away."
tra_nina schrieb:
For cable management, you can integrate special cable grommets into the back panels and run cable channels under the work surface. That’s exactly what I did. I drilled holes in the back panel and used cable clips. It works great for quick outlet adjustments. I use drawers for documents and pens, all organized with small boxes.
Here are a few ideas that have worked really well for me and are genuinely enjoyable: Use BESTA with a combination of drawers and doors. Drawers for items you use frequently, doors for things you use less often. I made small label stickers for each section, which really helps with quickly finding what you need. I also designed a drawer specifically for charging cables, using small elastic holders that I made myself. This keeps everything in place, and no more tangled cables! For electronic devices, I used small felt pads so the devices don’t slide around and are well protected. Give it a try, it really brings order to your space 🙂
soismail schrieb:
How can I use the BESTA series in my home office to have quick access to work materials while also keeping documents and electronic devices neatly stored? For both quick access and tidy storage, I recommend dividing the use into two sections: the upper drawers or open compartments should be used for daily writing tools, notepads, and frequently needed documents. The lower, closed compartments are ideal for less frequently used or archived papers and electronic devices. Use adjustable shelves to optimize the height and make the best use of available space. When storing electronic devices, make sure to use ventilated inserts to prevent overheating. For cable management, I suggest using dedicated cable clips and cable grommets integrated into the BESTA back panel. In addition to organizing modules, using color coding or labels helps maintain the structure.
