ᐅ How can I systematically assemble IKEA Metod cabinets with multiple drawers?
Created on: 12 Nov 2024 08:24
V
vinba
I am currently facing the challenge of assembling several IKEA Metod base cabinets, each with 3-4 drawers. I know the assembly instructions are well documented, but I am mainly looking for a systematic approach to efficiently and securely assemble multiple Metod cabinets with several drawers in a row.
How do you organize the assembly when putting together multiple cabinets at the same time?
- Do you follow a specific sequence when connecting the cabinet bodies?
- What is the best way to install the drawers to ensure nothing shifts or is misaligned?
- Are there any tips to avoid damage to the edges when assembling several cabinets one after another?
I would appreciate concrete, practical advice. Thanks!
Dilen
12 Nov 2024 16:47
Hello vinba,
For joining different widths and aligning them, I can recommend the following:
- Build the carcasses individually and check them for levelness.
- When connecting the carcasses, use IKEA’s connecting fittings, but be sure to ensure the carcasses are horizontally aligned.
- With varying widths, pay special attention to a common back panel – this provides the necessary stability.
- You should also assemble the cabinets on a level surface or compensate with shims.
vinba schrieb:
Do you have tips on how to best manage the alignment of different cabinet sizes, especially when positioning them connected?
To adjust the drawer fronts, use the small adjustment screws so that everything aligns flush.
Are there any constraints in your room that make positioning them difficult?
V
vinba
13 Nov 2024 07:12
Thank you, Dilen, for the suggestions!
Dilen schrieb:
Are there any space restrictions that make installation difficult for you?
Yes, the floor is not perfectly even, as I’m in an older apartment with slightly uneven tiles. So, I will probably need some kind of leveling supports to align the cabinets.
Palenar schrieb:
A quick question: Are all your cabinets the same height and width, or do you have different sizes?
They are not all the same, but the height is always either 80cm (31.5 inches) or 60cm (23.6 inches) for the smaller base cabinets.
Does anyone have experience with installing cabinets of different heights side by side, or is it better to place them separately?
nubar
13 Nov 2024 09:08
On the topic of uneven floors and varying heights:
It is certainly possible to place cabinets of different heights side by side, but only if they are not meant to be connected—otherwise, unevenness and height differences can cause problems later on.
I recommend using shims made of plastic or wood to level out floor irregularities.
If there are connection fittings, the cabinets definitely need to be the same height; otherwise, tensions or misalignments may occur.
Additionally, always check all drawers for smooth operation after assembly, as this is even more important with varying heights.
ju_ren
13 Nov 2024 11:45
I would add: If you want to connect cabinets of different heights, you can use a narrow trim strip between the fronts. This visually conceals small height differences very well.
warrenka57
14 Nov 2024 08:29
dijan schrieb:
A cabinet fully assembled – carcass, drawers put together, installed, adjusted – before moving on to the next one.
A step-by-step approach like this can also help reduce stress, especially with more complex setups.
vinba, since you mentioned using cabinets of different sizes, I would personally start with a basic cabinet prototype that covers as many features as possible.
After that, you can refine the process and minimize potential errors.
It’s always a mental exercise as well – don’t rush!
