I have a problem with a Malm bed from Ikea – it wobbles quite a bit, especially when moving or applying some weight to the bed. I have already checked that all the screws are tightened, but that only helped a little. The frame itself feels sturdy, but it seems like the connection between the side panels and the cross slats is not entirely stable. I am therefore interested in the best way to stabilize my Malm bed without making major modifications or completely disassembling it.
Are there any proven methods or tips specifically for this model? Would adding extra braces help, or using better tools during assembly? I look forward to your experiences and suggestions!
Dwight49 schrieb:
Could Onmeo please clarify whether the bed is placed on a hard floor or carpet?Thank you for the previous suggestions. The bed is standing on a wooden plank floor, which is not completely level – slight unevenness is definitely present.
I have also noticed that the slatted frame already has a bit of play because the bearing surfaces between the side rails and the slatted frame do not fit perfectly.
I’m considering whether spacers or wedges could be used here to secure the slatted frame more firmly before making any changes to the bed frame joints themselves.
Onmeo,
regarding your slatted bed base issue: Yes, using spacer strips can improve the support and should reduce wobbling. It is important that the slatted base rests completely flat. If the support surfaces do not fit precisely, the load distribution shifts unfavorably, leading to instability.
Additionally, you can install small rubber pads between the slatted base and the side panel. These absorb vibrations and increase stability without causing tightness.
One more tip: After stabilizing, check the screws again – by applying glue into the screw holes, you can further increase firmness without the screws being visible.
JAPLO schrieb:
One more tip: After the structure has been stabilized, check the screws againI completely agree with you. And if you decide to use wood glue, don’t apply too much! Excess glue often makes the material more brittle. Just a few drops that get drawn into the screw holes are more than enough.
I would also recommend using some fine sandpaper after cleaning the screw holes to remove any old glue residues. This helps ensure a better bond.
By the way, if you think of the floor like a puzzle, small anti-slip pads under the feet can work wonders, especially on smooth plank floors. 🙂
Onmeo schrieb:
I am considering whether to use spacer strips or shims hereThat’s a good approach. When selecting spacer strips, make sure they are made from solid wood or composite material that has minimal tendency to swell or shrink.
Also, try using wood clamps at the joints of the bed frame parts to press the connections overnight. This way, you can add some extra reinforcements with wood glue that will significantly reduce wobbling.
If you decide to use metal brackets, choose stainless steel ones with a slim design, so they are not too visible but still fully functional.
One more question: Have you tried assembling the bed temporarily on the balcony or on a level surface to rule out wobbling?
