ᐅ How can I stabilize Malm furniture?
Created on: 15 Mar 2019 18:23
V
Volfus
V
Volfus
15 Mar 2019 18:23
Some time ago, I bought a set of IKEA Malm furniture. However, I have noticed that it tends to be quite wobbly, especially after extended use. How can I stabilize Malm furniture without compromising its appearance and functionality? Are there specific techniques or materials that work well to reinforce the joints or generally improve stability? I prefer solutions that provide long-lasting stability, as I don’t want to have to adjust everything every few months.
Thanks in advance for any helpful advice!
Gerard
15 Mar 2019 19:07
Hello Volfus,
To make Malm furniture more stable, it is recommended to first check all joints and screws. Connection elements often loosen with use. Usually, tightening the screws carefully with a screwdriver or cordless drill (without over-tightening) is helpful.
An additional very effective step is to reinforce the corner joints afterward with metal angle brackets or L-profiles. These profiles are attached on the inside of the furniture so that the exterior appearance is not affected. Small universal screws are used for this, which are screwed into the wood.
For further stabilization, inserting wooden dowels into the existing joint holes can help, especially if the furniture is starting to wobble. This permanently tightens the connections, particularly in older pieces.
Additionally, attaching felt pads or non-slip pads underneath the furniture can reduce wobbling caused by uneven floors.
I hope these measures help you.
LOSAR
15 Mar 2019 20:45
Check and tighten all screws.
Install angle brackets on the inside.
Insert wooden dowels if necessary.
Place protective pads underneath.
Usually, no more is required.
V
Volfus
16 Mar 2019 09:37
Gerard schrieb:
An additional, very effective step is to reinforce the corner joints afterwards with metal angle or L-profiles.
Thank you for the tip, that sounds reasonable. What is the best way to install such angle profiles? Is there a preferred screw size or arrangement I should consider? My concern is avoiding damage to the furniture during retrofitting or screws not holding properly afterward.
I would also be interested to know if there are alternatives to metal angles that might be less visible or easier to install.
Giagau
16 Mar 2019 11:12
Regarding the question about angle brackets:
It is recommended to use angle brackets with a thickness of around 1.5 to 2 mm (0.06 to 0.08 inches), as they are sturdy yet can still be easily fastened with wood screws. The screws should not be too long, typically 15-20 mm (0.6 to 0.8 inches) countersunk wood screws, so they sit flush.
The brackets should be positioned on the inside corners, ideally securing both the side panel and either the back panel or the top of the piece of furniture. It is important to pre-drill the mounting points to avoid splitting the wood.
As an alternative to metal angle brackets, strong wooden strips can also be used, joined with wooden dowels and wood glue. This solution is more visually discreet but requires some craftsmanship and time for drying and precise fitting.
Volfus schrieb:
Are there alternatives to metal angle brackets that may be less visible or easier to install?
The wooden strip method or specialized furniture connectors (e.g., clamps or clips) can also provide stability, but these options are generally more suitable for larger pieces of furniture.
I hope this clarifies some details.
