ᐅ How can I stabilize MALM furniture for frequent use?
Created on: 19 Aug 2019 18:22
Kefeteo
Kefeteo
19 Aug 2019 18:22
I have a practical question: How can I reinforce Malm furniture from IKEA (specifically dressers and drawer units) to withstand frequent use? In my case, the drawers and the entire structure already feel noticeably wobbly after a few months, which bothers me because the furniture seems quite sturdy at first.
I have considered adding extra screws or brackets, but I’m unsure where exactly would be most effective without affecting the appearance or causing damage. Are there any other proven methods to stabilize these pieces during regular use, especially if you want to stick mostly to the original materials?
Best regards!
poted
19 Aug 2019 18:55
Hello Kefeteo,
Regarding the stabilization of MALM furniture with frequent use, there are a few aspects to consider:
Basically, MALM furniture is made of particleboard with a laminate surface, which limits its load-bearing capacity and can especially cause wobbling and wear in moving parts like drawers. It is important to first check whether the original screws are tight and, if necessary, retighten them.
1. Angle Brackets: Inside the chest of drawers (preferably behind the side panels), small metal angle brackets add more stability, especially at the edges where the panel connects with the back wall. Always be careful not to work too roughly to avoid damaging the surface.
2. Check Drawer Slides: The most common defect comes from play in the drawer slides. Replacing them with sturdier slides (e.g., metal ball-bearing runners) significantly improves smoothness and stability.
3. Additional Crossbars: Sometimes adding an extra wooden crossbar below the top shelf helps prevent deformation of the side panels and wobbling.
4. Floor Contact: Since MALM furniture has no direct floor supports, using felt pads or small feet with rubber rings provides better grip and reduces sideways tipping.
Important: What are the exact dimensions and variant of your MALM furniture (e.g., chest of drawers with 4 drawers, width, etc.)? Do you use the furniture in a household environment or subject it to particularly heavy use (children’s room, office)? This helps to better address any damage.
Best regards!
Fitigu
20 Aug 2019 09:11
the following effective principles apply to stabilizing MALM dressers with frequent use:
- Regularly check screws for tightness and, if necessary, reinforce them with wood dowel adhesive.
- Replace the standard metal brackets with sturdier steel brackets featuring edges of at least 30 mm (1.2 inches) in length.
- Using metal drawer slides instead of the original plastic or particleboard guides improves drawer stability.
- Adding a cross brace, such as a wooden beam at the back panel, distributes loads and prevents deformation.
- Adjustable furniture feet for floor contact are recommended to compensate for uneven surfaces and prevent wobbling.
These measures are practical and do not cause significant modifications to the piece of furniture.
Incidentally, MALM is not designed for very heavy loads due to cost and weight-saving considerations.
Regards
LANICOLE
20 Aug 2019 19:58
Hello Kefeteo,
I would like to provide a brief guide that covers both basic and advanced steps:
1. Inspection & Preparation
- First, loosen all screws and then tighten them again.
- Check all wooden dowels for a secure fit. Loose dowels can be stabilized with wood glue.
2. Adding Reinforcements
- Screw metal brackets inside, behind the side panels where the side meets the bottom and intermediate shelves.
- Make sure the brackets are not visible from the outside to preserve the appearance.
3. Improved Drawer Slides
- Replace the “galvanized” drawer slides with higher-quality ball-bearing slides.
- This prevents shaky movement and extends the lifespan.
4. Cross Bracing
- Possibly the best option: additional wooden cross braces mounted on the back between the side panels prevent twisting and wobbling.
5. Floor Stabilization
- Furniture feet, such as height-adjustable plastic feet or pads with anti-slip layers, prevent shifting or tipping.
Common mistakes I see:
poted schrieb:
"Angle reinforcements: Inside the dresser (preferably behind the side panels), small metal brackets add more stability"
- Don’t forget that the original back panel is often just a thin particle board. It’s worth screwing on an additional wooden panel or 3 mm (1/8 inch) MDF sheet behind it for more strength.
In summary:
The combination of retightening screws, internal brackets, better slides, and cross braces creates a very sturdy MALM dresser.
I hope this helps!
Muso4
21 Aug 2019 11:37
Kefeteo schrieb:
With frequent use, the drawers and the entire construction become noticeably wobbly after just a few months
I see it differently: Why not simply accept that furniture made from particleboard naturally shows signs of wear? To me, all this "reinforcement" is a symptom of our throwaway society and an approach that doesn’t really solve the underlying problem.
MALM furniture is affordable and not meant to last forever. If someone has higher expectations, they should invest in solid wood instead. In that sense, reinforcements are more of a temporary fix than a real solution.
Of course, you can go ahead and add screws, replace drawer slides, etc., but in the end, that effort cancels out the cost advantage.
So, if you ask me: just adjust regularly, and when it gets too wobbly, replace it. Simple. 🙂
