ᐅ How can I stabilize Malm furniture to withstand building vibrations?
Created on: 24 Jul 2021 10:12
jakebuHello everyone,
I have an issue with my IKEA Malm furniture, specifically regarding its stability during minor building vibrations caused by nearby construction work. The furniture is placed quite close to a wall and seems to wobble or shift slightly when there are vibrations, which concerns me due to possible damage and safety risks.
I am particularly interested in options to make these relatively lightweight but tall pieces more stable without extensive drilling or significantly altering the wall. I am thinking of solutions like additional fasteners, clamp devices, or special anti-slip materials.
Unfortunately, I haven’t been able to find reliable information, especially on solutions that are both practical and reversible, as I might want to move the furniture at some point.
Does anyone here have experience or recommendations on how to safely secure my Malm cabinets against these recurring but not very strong vibrations without damaging the furniture or modifying the wall?
Thanks in advance!
Thanks in advance!
Hello Jakebu,
First of all, thank you for your detailed question. Your concern about the Malm furniture wobbling due to building vibrations is completely understandable, as their height and lightweight materials can make them prone to movement.
I recommend securing the furniture firmly to the wall as a first step. IKEA often provides safety kits for this purpose, which can be installed without major drilling, at least when using appropriate wall plugs and screws.
If you want to avoid drilling altogether, I suggest using anti-slip pads (a type of foam rubber or silicone mat) under the furniture to prevent it from sliding. Additionally, you can use furniture brackets that clamp between the furniture and the wall; these are reversible and do not cause damage.
Summary:
1. Secure furniture with wall brackets (preferably with suitable wall plugs)
2. Attach anti-slip pads to the feet
3. Use furniture brackets for additional stabilization
Common mistakes include insufficient wall anchoring or neglecting floor grip, which is often the main reason for tipping movements.
Summary:
Hello Jakebu,
I would like to approach this topic from a more technical perspective, as the mechanical behavior of furniture under vibrations can be quite complex. Malm furniture is usually made of particleboard, relatively lightweight and tall, so the location and load distribution play a crucial role here.
First, you should determine the frequency and amplitude of the vibrations, for example by using simple smartphone apps for vibration measurement or by observing how strong the shaking actually needs to be to unsettle your furniture.
Then it is important to secure the furniture safely while allowing the forces generated to be dissipated in a controlled way. The classic method is to fix the furniture to the wall using brackets, but since you want to avoid drilling, there are alternatives:
1. Clamping systems: There are clamping strap systems designed specifically for tall furniture that are wedged between the ceiling and the furniture, similar to shelving units. This provides upward support that prevents tipping.
2. Anti-slip materials: High-quality silicone mats with a strong friction coefficient can be placed directly under the furniture. Note: For smooth floors such as tile or laminate, you should test if the grip is sufficient.
3. Increasing weight: If possible, place heavy objects at the bottom of the cabinet to reduce the likelihood of movement.
4. Reinforcement: Easily attachable reinforcement profiles made of aluminum or wooden planks can make the furniture structure itself more stable (e.g., internal side-mounted braces).
Finally, please make sure to check the wall construction before installation – drywall (gypsum board) is less load-bearing than solid masonry. The securing must always be anchored to a load-bearing wall surface.
I would also be interested to know: How strong are the vibrations in your building? Are they continuous vibrations or isolated shocks, for example from construction vehicles?
Domau0 schrieb:
How strong are the vibrations in your building? Are they continuous vibrations or single jolts, for example from construction vehicles?Good question, they are usually short, single jolts, mostly when heavy machinery is operating nearby. No constant vibrations, more like a kind of shaking lasting a few seconds.
The walls are quite solid; it is an old building with thick brick walls, so very load-bearing. The floor is parquet, not tiles.
kemads46 schrieb:
I recommend securing the furniture firmly to the wall as a basic measure. IKEA often offers safety kits for this. Safety kits sound good, but I’m worried that drilling in screws might actually damage the furniture. Are there gentler alternatives that are still effective?
Thanks to everyone involved so far.
Hello Jakebu,
I understand your concern regarding the screws on the Malm furniture. These often damage the crossbeam, which can be frustrating.
A gentler method that I always recommend is using so-called furniture tension rods. These are clamped between the floor and ceiling and then press the furniture securely against the wall—without any drilling or screws.
This also effectively prevents the furniture from tipping over. They work especially well in older apartments with high ceilings. It is important to measure the exact ceiling height beforehand to get a rod of the right length.
Additionally, you can further improve stability with high-quality non-slip mats. These create a strong frictional connection between the furniture and the parquet flooring.
Perhaps a combination of a furniture tension rod and a non-slip mat would be the best solution for you.
