ᐅ How can I childproof Malm dressers to make them more stable?
Created on: 6 Jul 2021 08:12
kujeren
I own several IKEA Malm dressers and want to install them in the house as child-safe as possible. Since my little ones are often curious and sometimes climb on furniture, a stable, secure fastening is important to prevent tipping accidents.
I’m interested in which methods you find particularly effective for stabilizing Malm dressers that are also technically easy to implement and child-friendly – meaning no protruding screws or hazards, but still maximally stable.
It would also be helpful to know if you have used any specific products or tools and whether the installation can be done without extensive DIY skills.
Looking forward to practical tips and experiences!
sanjon
7 Jul 2021 10:03
GUSTAVO56 schrieb:
"If you like, I can give you exact recommended types of anchors and screws for drywall."
That would be great. Quality and the right choice of materials are key here.
It’s also interesting to know whether the anchors can be easily removed later in case of moving.
GUSTAVO56
7 Jul 2021 12:12
Sure, gladly.
For drywall installation, I usually use Fischer HM cavity metal anchors:
- They are sturdy and can support loads up to 50 kg (110 lbs) per anchor.
- Length: at least 6 cm (2.4 inches), depending on the board thickness.
- Recommended screw diameter is 4-5 mm (0.16-0.20 inches).
These anchors distribute the force well inside the cavity and can be removed with some patience during relocation (however, holes left behind are unavoidable).
I use zinc-plated Phillips screws because they are rust-resistant and hold firmly.
If you move the chest of drawers, be sure to use new anchors, as drywall anchors lose their holding power when removed.
If the child is very active, it is better to use two anchoring points per chest of drawers to fully prevent tipping.
In my opinion, this is the optimal combination—a good balance between durability and effort.
kujeren
7 Jul 2021 14:05
Sanjon schrieb:
"Quality and the right choice of materials are key here."
I agree completely. Thanks @GUSTAVO56 for the detailed recommendations.
I will probably start with the IKEA straps and, if needed, the good Fischer HM cavity wall anchors. The idea of using two anchor points per dresser sounds reasonable.
Tobias schrieb:
"The installation is simple and the straps are unobtrusive."
Regarding the appearance, I now consider the straps acceptable. Safety comes first after all.
You all have been very helpful. I will report back on how it went once I have secured the cabinets. Thanks to everyone for the useful answers! :-)
JORDON
8 Jul 2021 08:37
Glad to hear you have a solid plan! Safety is always a combination of technology and practical experience – and when it comes to lifting the little ones, you’ve got to keep an eye on them 😉
And remember, it’s all about the materials and how you handle them. May stability be with you! 🙂
