ᐅ How can I stabilize MALM beds on uneven floors?
Created on: 2 May 2023 10:23
Kibo66
Kibo66
2 May 2023 10:23
I recently bought a MALM bed from IKEA and noticed that the floor in the room is quite uneven. When moving the bed, there is a slight wobble or rocking, which is obviously annoying over time. My question is: How can I effectively and permanently stabilize MALM beds on uneven floors?
I have considered using small leveling wedges or felt pads under the legs, but I’m not sure if that is enough or just a temporary fix. Are there any proven methods that any of you have tried, such as special underlays, screws, or modifications to the bed frame itself?
It is important to me that the stabilization is not just a short-term help but really robust so that the bed does not loosen again over time.
I look forward to tips, suggestions, or experiences, including technical explanations on why a particular method works well.
FLONE41
2 May 2023 11:12
Hey Kibo66,
I completely understand how annoying it is when the bed wobbles. It was the same for me after moving. I initially placed small rubber pads under the bed legs, which helped prevent slipping. However, you need to check them regularly because they can compress over time.
[quote=Kibo66, post: n2p8z4, member: XXX]Are there any proven methods that some of you have tried, like special underlays...
I think it’s a good idea to fix the legs in place if possible. I experimented with self-adhesive hook and loop tape, which stabilizes the bed somewhat, especially on smooth floors. Sometimes securing the bed frame to the wall can also help, if that’s an option.
It can be frustrating since it feels like you always have to readjust something. But it’s worth sticking with it!
gasidney
2 May 2023 11:56
Hi,
try adjustable floor protectors (also height-adjustable). You can precisely adjust them and stabilize well.
Alternatively, use small wooden wedges if the floor is too uneven.
gadalu
2 May 2023 13:08
Very good question.
To stabilize a MALM bed on uneven flooring, I first recommend a systematic check of each bed leg for height differences at the location. For floor irregularities of about 3 mm (0.1 inches) or more, flexible adjustments are advisable.
1. Height-adjustable furniture glides: These usually consist of plastic with a screw base, allowing fine adjustments of a few millimeters, which helps to compensate for height differences.
2. Intermediate layer made of rubber-like material: Rubber mats can provide slip resistance and even out minor unevenness.
3. Wedges made of wood with a suitable shape: For more pronounced floor irregularities, wedges can be placed under the feet and fixed with tape.
4. Permanent mounting by screwing: If possible, additional angle brackets can be attached to the underside of the bed and the floor (or wall) to stabilize the structure.
It is important to ensure that the load on the bed frame and mattress remains evenly distributed to avoid increased stress points.
kaubi
3 May 2023 08:45
Hello Kibo66,
I will address your concern in more detail, as the issue of uneven floors is often underestimated and can be quite complex with a MALM bed.
First: MALM beds are basically equipped with four legs that provide stability at a relatively low height. On uneven floors, rocking movements inevitably occur because the forces cannot be distributed evenly.
Step 1: Floor check – Use a spirit level to measure the unevenness at all four support points of the bed. Even small deviations of 2-4 mm (0.08-0.16 inches) can cause wobbling.
Step 2: Shimming materials – For slight unevenness, rubber pads with a self-adhesive backing are recommended, as they are non-slip and can easily compensate for height differences. If the floor is very uneven, wooden wedges are better because they can be shaped individually. Make sure to prepare the surface properly so the wedges do not slip.
Step 3: Adjustable furniture glides – Versions with a metal screw and plastic tip are recommended. They allow adjustments with millimeter precision. Advantages: durable and reusable.
Step 4: Connecting the bed legs – To minimize lateral rocking, you can reinforce the legs with angled braces made of wood or metal. This is especially helpful for more pronounced unevenness. A stable base also prevents the frame’s screw connections from loosening.
Step 5: Wall fixing – If the room allows, additional securing with brackets to the wall is advisable. This prevents tipping and significantly improves stability.
In conclusion: If you choose wedges or other underlays, make sure the height adjustment is precisely matched to the bed. Raising one leg too much can cause more problems than it solves.
How uneven is your floor exactly? Can you provide more precise measurements?
Kibo66
3 May 2023 09:17
kaubi schrieb:
How uneven is your floor exactly? Can you provide more precise measurements?\
Thanks for the detailed information!
I checked the floor with a spirit level and found that the largest deviations are around 5 mm (0.2 inches), so they are quite noticeable. However, the uneven spots are not concentrated in just one area but are somewhat spread out under the legs. Therefore, I suspect that classic wedges in individual corners might help but may not be the optimal solution.
FLONE41 schrieb:
screwing the bed frame to the wall\
Unfortunately, that’s not possible for me because it is located directly under a window.
I will try height-adjustable furniture glides and possibly rubber-like pads as well, thanks for the tip.
Are there any recommendations regarding the screws or load distribution to consider? For example, whether the bed frame is particularly stressed due to the uneven floor and if there are any preventive measures to take?
